Zack1978
- November 24, 2011
- 1999 Ford Explorer
Hi everyone,
I have a 1999 Explorer, and the ignition switch is worn out and broken. The switch is so worn that you can simply pull the key out while the truck is running. Also it is now not returning to the lock position, without force.
How hard is it to replace the ignition switch? What are the steps to doing this job?
What difficulties will I run into since my key has a chip in it, and the truck will not start without the chip key. I was on Rockauto and they have a Motorcraft part for $55.00 with keys (http://www.rockauto.com/catalog/raframecatalog.php). Will that part work on my truck? Will I need to have it towed to a dealer for the keys to be reprogrammed? Any ideas?
Thanks,
Zack
Thanks,
Zack
