2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Background
A nonfunctional mass air flow (MAF) sensor can significantly degrade engine performance. The PCM utilizes the MAF sensor output voltage to determine engine load which is used to adjust the air/fuel ratio during acceleration. The typical engine performance symptoms caused by a dirty or defective MAF sensor are lack of power and hesitation during acceleration. The MAF sensor element wires become dirty with age and become contaminated from excessively oiled air filters. Cleaning the element with MAF sensor cleaner should be performed frequently and often will cure MAF related engine performance issues.
Testing
With the MAF sensor electrical connector connected backprobe the sensor signal (light blue/red wire) and the sensor return (tan/light blue wire) at the connector.
Connect the positive lead of a voltmeter to the sensor signal and the negative lead to the return.
With the parking brake set and the gear selector in Park start the engine.
Monitor the MAF sensor output voltage while increasing engine speed. The voltage should increase smoothly with no dropouts as the engine speed increases. Listed below are representative values.
RPM Voltage
550 0.8
1000 1.0
1500 1.25
2000 1.4
2500 1.55
3000 1.65
3500 1.9
4000 2.1
Testing
RPM Voltage
550 0.8
1000 1.0
1500 1.25
2000 1.4
2500 1.55
3000 1.65
3500 1.9
4000 2.1
