SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
SOLUTION FOUND SOLUTION FOUND
UPDATED ON June 22, 2008 - READ BELOW!
I have a 2002 Explorer. The Check Engine Soon light stays on. The engine idles rough and sometimes dies as the RPM bounces between 650 - 800 RPM. At normal driving speeds and acceleration I do not seem to notice a problem. Oftentimes, at a red light, I'll put it in neutral and tap the accelerator just a tad to make sure it does not die on me at the intersection. Oddly, if you try to keep it idling at around 1000 RPM you'll see the tach jump up to 2000 RPM then back down to 800 RPM. It is very difficult to give it just enough gas and keep it a constant 1000 RPM when sitting there at a red light. Is there an easy way to read out the ERROR CODE without special tools? Anyone have a good guess as to what the problem is?
I have the V-8 engine and it has 91K miles on it.
