| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum |
Thread Tools |
#1 |
NJ
2003 Explorer.
Hard to shift.
Hey guys. It's an honor to be on this forum. I recently purchased a2003 explorer sport. I have only 2 problems with it as of now. The trunk latch is broken. So I can't open it. I would appreciate someone pointing me into the right direction. I'm also having a hard time shifting in to gears. It's like I have to yank it in place. Could it be just my shiter or the slave or master cylinder or is an issue in the tranny? Once again any help is greatly appreciated.
Trupal. |
#2 |
NJ
2003 Explorer.
Anybody?
#3 |
Wannabe Elite Explorer
Fresno, California
'00 FX4 Ranger
You may want to try bleeding the clutch a few times. If that doesn't help, try using the vacuum type bleeder. Again, if that doesn't help time for a new CLUTCH jobs, just make sure you replace everything new (slave cylinder, pilot bearing, ect.)
__________________ 1. XLT Ranger 4dr 4.0 5 spd 4X4-> K&N filter, grill insert, Stainless steel skid plate, 98 Mountaineer front axles swap, factory motor transplanted and new clutch kit, 3" Flowmaster 40 dual outlet, hard bedcover, JamesDuff traction bars, Bilstien shocks. 2. 1999 K1200RS BMW motorcycle <fast German technology> 3. 2005 Suzuki XL 7, the only small SUV with 7 passengers I could effort under $15K 4. 1970 VW project -needs exhaust, interior, extrical parts.. |
#4 |
NJ
2003 Explorer.
Thank you ranger Al. The clutch was replaced about 30k ago. Not sure about the slave or the bearings. The motor was replaced 40 k ago. But I will be sure to go over what you said. I will post my results tomorrow. Once again, thank you.
Trupal |
#5 |
Fresno, California
'00 FX4 Ranger
The clutch system is one of the toughest to remove air. So, it is going to take a few tries to get where you wanted to.
#6 |
#7 |
Denver Colorado
'93 Explorer XLT
How goes? I had a similar issue with my manual, and even though I was only getting fluid out, bleeding it helped immensely.
#8 |
Fresno, California
'00 FX4 Ranger
I know it is an old post, how does it go? If you have hard time bleeding and still doesn't work, inspect the brake assembly (thats the pot aluminum casting). The pivot point does break and will need to be replace.
#9 |
Fresno, California
'00 FX4 Ranger
I've been searching and reading up on these master cylinder. The proper way to bleed these system is to bench bleed the master cylinder with the entire line off and do a bleed and the master cylinder have to be at certain angle where the air will come up to the reservoir as you push in the rod in gently back and forth.
Well, I wasn't about to remove the unit. But rather put ramps onto the rear end and drive it back to lift the rear of the truck. I then do my normal bleeding and sure enough after a few tries. NO MORE AIR coming out! __________________ 1. XLT Ranger 4dr 4.0 5 spd 4X4-> K&N filter, grill insert, Stainless steel skid plate, 98 Mountaineer front axles swap, factory motor transplanted and new clutch kit, 3" Flowmaster 40 dual outlet, hard bedcover, JamesDuff traction bars, Bilstien shocks. 2. 1999 K1200RS BMW motorcycle <fast German technology> 3. 2005 Suzuki XL 7, the only small SUV with 7 passengers I could effort under $15K 4. 1970 VW project -needs exhaust, interior, extrical parts.. |
#10 |
Denver Colorado
'93 Explorer XLT
So that worked?
#11 |
Fresno, California
'00 FX4 Ranger
Yup, the air bubble start coming out. You also want to keep an eye on the reservior making sure it does not go empty and will see small bubble coming out of the hole. I guessed the key is to be patient and take your time.
#12 |
GREEN SCREAM!!
Hattiesburg, MS
'93 Sport 4x4
Bleeding multiple times certainly does help, but when the master/slave wears out, they simply must be replaced to get the regular operation back. Otherwise no amount of bleeding will cure a mechanical issue.
Also keep in mind a fluid change sometimes helps, just be sure to use Dex/Merc ATF in the earlier transmissions that call for Mercon, and use Mercon V in the newer ones that spec it. __________________ "I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins |
#13 | |
Oregon Coast and Portland
1999 Explorer Sport 4x4
Quote:
Having shifting 1-2 and 3-4 trouble with my recently acquired '99 4x4 Sport, that had a new clutch kit about 6k miles ago. Thanks. |
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| OBD-II Diagnostic Trouble Codes (DTCs) | BobWiersema | EEC V | 8 | 03-26-2013 10:22 PM |
| Delayed hard shift | m-mjones | Under the Hood | 5 | 04-10-2010 05:33 PM |
| 03 Whining Noise and Hard 2-1 Shift | 03_Black_EB | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 6 | 09-17-2009 10:48 PM |
| hard 1st shift | laybac | Stock 1995 - 2001 Explorers | 3 | 12-09-2007 04:03 PM |
| Thread Tools | |
