- January 11, 2001
- McVeytown, PA
- '18 XLT
Here is a compiled list of the TSB's that are out on the 2011, 2012 and 2013 Explorers. If you know of one that is not on the list, please PM me with the listing and I will add it. I'm also adding in the full description as I come across them.
- 12-2-7 TIN ROOF NOISE - FRONT ROOF AREA DURING RAIN - BUILT ON OR BEFORE 11/5/2011
- Publication Date: February 10, 2012
FORD: 2011-2012 Explorer
ISSUE:
Some 2011-2012 Explorer vehicles built on or before 11/5/2011 may exhibit a noise similar to rain hitting a tin roof. The noise is coming from the front passenger compartment.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Remove both sun visor screw covers and allow both visors to hang down.
Install shop towels or equivalent directly beneath the foam insertion points to protect the interior of the vehicle.
Using Fusor® 121 flexible foam repair kit.
Install a mixing tip onto the expandable foam cartridge.
Attach a 15.24 cm (6") piece of 0.635 cm (1/4") ID x 0.952 cm (3/8") OD (max) rubber tubing to the mixing tip.
Secure the rubber tubing to the mixing tip with a cable tie, tape or clamp. (Figure 1)
Figure 1 - Article 12-2-7
NOTE: ONCE THE PRODUCT STARTS MIXING IN THE MIXING TIP YOU NEED TO WORK VERY QUICKLY.
Starting on the left side of the vehicle.
Locate the square opening on the rearward side of the sun visor mounting cup. (Figure 2)
Figure 2 - Article 12-2-7
Insert rubber tubing all the way into this opening while curving the tubing toward the center of the vehicle. (Figures 3 and 4)
Figure 3 - Article 12-2-7
Figure 4 - Article 12-2-7
Pull the handle enough to fill the mixing tube. Once full, pull the handle an additional three (3) times.
Withdraw the hose 25 mm (1"), then pull the handle two (2) times. Repeat this four (4) more times, withdrawing the hose 25 mm (1") each time.
Repeat on the right side of vehicle using new mixing tube and rubber tubing.
Allow the product to fully cure following manufacturers recommendations.
After curing, remove any excess foam that may be in the sun visor mounting cup.
Remove protection from vehicle interior.
Install sun visor assemblies and install the two (2) sun visor screws.
Install the sun visor screw covers.
This procedure will improve, but may not eliminate the noise entirely.
Locally Obtained Supplies
Part Number Description
121 Fusor® 121 flexible foam repair kit
N/A Cable Tie
N/A Tape
N/A Clamp
N/A Rubber Hose 0.635 cm (1/4") ID x 0.952 cm (3/8") OD"
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120207A 2011-2012 Explorer: Install Foam Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.5 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
7850202 68
- 12-2-6 POWER LIFTGATE DOES NOT OPEN OR REVERSES AFTER OPENING APPROXIMATELY 25 MM (1 INCH)
FORD: 2012 Explorer
ISSUE:
Some 2012 Explorers vehicles equipped with the power liftgate may not open or open approximately 25 mm (1 inch) then reverse when using the power open feature.
ACTION:
SERVICE PROCEDURE
Remove the liftgate striker bolts and striker.
Discard striker.
Install the new liftgate striker.
Torque striker bolts to 22 N-m (16 lb-ft).
PART NUMBER PART NAME
BB5Z-7843252-A Striker
WARRANTY STATUS:
120206A 2012 Explorer: Replace The Liftgate Striker (Do Not Use With Any Other Labor Operations) 0.2 Hr.
DEALER CODING
7843252 16
PROGRAM CODE
T11
- 12-1-11 A-PILLAR TRIM RATTLE AND/OR BUZZ - BUILT ON OR BEFORE 11/21/2011
Publication Date: January 19, 2012
ISSUE:
Some 2011-2012 Explorer vehicles built on or before 11/21/2011 may exhibit a buzzing, howling, or rattle noise at higher vehicle speeds and/or cross winds, from the windshield A-pillar appliques.
ACTION:
SERVICE PROCEDURE
Remove and discard A-pillar appliques, refer to Workshop Manual (WSM), Section 501-08.
Check old applique for any clips that may have come out of the bracket and if necessary remove and reattach to bracket as necessary. Refer to WSM, Section 501-08.
Wipe the lower rubber gasket with a damp rag (no chemicals) to clean the butyl contacting surface.
The lower rubber gasket is located on the windshield side of the bracket.
Remove protective film from the butyl tape on the new applique.
Install new applique, refer to WSM, Section 501-08.
The applique has an alignment features at the top and bottom of the applique that must be aligned before snapping the middle clips into place.
BB5Z-7803136-AB Moulding (Right Hand)
BB5Z-7803137-AB Moulding (Left Hand)
WARRANTY STATUS:
120111A 2011-2012 Explorer: Replace Both (2) Windshield Appliques (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
7803136 33 - 12-1-8 DUAL AUTOMATIC TEMPERATURE CONTROL (DATC) - BLEND DOOR ACTUATOR INOPERATIVE
ISSUE:
Some 2011 Explorer vehicles equipped with DATC system may experience unresponsive temperature change when requested and/or erratic temperature change.
ACTION:
SERVICE PROCEDURE
Remove temperature blend door actuators, refer to Workshop Manual (WSM), Section 412-00.
Suspect parts have a black cover and new service part has a white cover.
Remove alignment feature from new actuators. (Figure 1)
Figure 1 - Article 12-1-8
Support actuator flange so there is not stress on the actuator body. (Figure 2)
Figure 2 - Article 12-1-8
Drill out the 2 webs with a 3.17 mm (1/8") drill bit. (Figure 3)
Figure 3 - Article 12-1-8
Install new actuators, refer to WSM, Section 412-00.
Reprogram the Heating Ventilation Air Conditioning (HVAC) module to the latest calibration using IDS release 76.04 and higher or 77.01 and higher. This new calibration is not included in the VCM 2012.1 DVD. Calibration files may also be obtained at www.motorcraft.com.
AA5Z-19E616-C Motor Assembly
WARRANTY STATUS:
120108A 2011 Explorer: Replace The Blend Door Actuators Includes Time To Modify The New Actuators And Reprogram The HVAC Module (Do Not Use With Any Other Labor Operations) 1.1 Hrs.
DEALER CODING
19E616 42 - 11-12-10 6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011
TSB 11-12-10
12/22/11
BEFORE 4/15/2011
FORD:
2010-2011 Taurus
2009 Edge, Flex
2010-2011 Edge, Flex
2011 Explorer
LINCOLN:
2010-2011 MKS
2009 MKX
2010-2011 MKT, MKX
This article supersedes TSB 11-9-11 to update the Service Procedure.
ISSUE
Some 2009 Edge, MKX and Flex vehicles built on or after 5/4/2009, 2010-2011 Edge, Flex, MKS, MKT, MKX, Taurus and 2011 Explorer vehicles built on or before 4/15/2011 may have a sluggish acceleration or hesitation feel during a rolling stop 0-8 Km/h (0-5 MPH) followed by a harsh bump or feel like a slip on take-off from a stop followed by a harsh bump.
ACTION
SERVICE PROCEDURE
This valve body modification is only available for transmissions originally built with MERCON® LV listed on the dipstick.
There is a new calibration and transmission valve body change to correct this condition. The valve body change was to delete one hole in the valve body separator plate and remove one check ball from the valve body in the same area where the hole in the separator plate was deleted.
NOTE
IF THIS PROCEDURE IS NOT FOLLOWED CORRECTLY, ADDITIONAL NEW CUSTOMER SYMPTOMS WILL BE PRESENT, SUCH AS LOSS OF REVERSE OR 2-3 SHIFT FLARE.
1. For all model years except 2009, proceed to Step 2. For 2009 model year vehicles, verify the transmission dipstick has MERCON(R) LV listed on the dipstick.
a. Yes - The dipstick has MERCON(R) LV listed on the dipstick; proceed to Step 2.
b. No - The dipstick does not have MERCON(R) LV listed on the dipstick; this procedure does not apply. Follow normal Workshop Manual diagnostics.
2. Reprogram the PCM to the latest calibration using IDS release 73.04 and higher. This new calibration is not included in the VCM 2011.5 DVD. Calibration files may also be obtained at the website.
3. Remove the transmission valve body. Refer to the Workshop Manual (WSM), Section 307-01.
4. Replace both separator plates listed in the Parts List. The X identifies the hole in the valve body separator plate which will be eliminated. (Figure 1)
a. Proper check ball locations on the remaining six (6) valve body check balls shown with arrows. (Figure 2)
5. Remove one (1) check ball identified as X. (Figure 2)
6. Install transmission valve body. Refer to WSM, Section 307-01.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT : Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
- 11-12-9 INTERMITTENT COLD TEMPERATURE GAUGE READING AFTER HOT SOAK RESTART - BUILT ON OR BEFORE 8/11/2011
- 11-12-7 INTERMITTENT OIL PRESSURE WARNINGS WITH KEY ON ENGINE OFF OR WHILE CRANKING - BUILT ON OR BEFORE 8/11/2011
TSB
Publication Date: December 16, 2011
FORD: 2011 Edge, Explorer
LINCOLN: 2011 MKX
ISSUE:
Some 2011 Edge, Explorer and MKX vehicles built on or before 8/11/2011 may exhibit intermittent oil pressure warnings with key on engine off (KOEO) or while cranking without any other oil pressure concern type symptoms.
ACTION:
Reprogram the instrument panel cluster (IPC) module to the latest calibration using IDS release 76.03 and higher. This new calibration is not included in the 2011.11 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
IMPORTANT: Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
111207A 2011 Edge, MKX, And Explorer: Reprogram The IPC Module (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
10849 04
- 11-11-15 3.5/3.7L - COLD ENGINE STARTUP TICKING NOISE
- 11-11-12 RAIN SENSITIVE WIPERS - UN-COMMANDED OR PHANTOM WIPE ON DRY GLASS - BUILT ON OR BEFORE 6/26/2011
- 11-11-7 PULL/DRIFT RIGHT ON ACCELERATION - 3.5L ENGINE AND FRONT WHEEL DRIVE (FWD) ONLY - BUILT ON OR BEFORE 10/20/2011
- 11-10-31 CROSS TRAFFIC ALERT (CTA) - AUDIBLE WARNING DISABLED - BUILT ON OR BEFORE 1/21/2011
- 11-10-29 FRONT BRAKES - INTERMITTENT SQUEAL
ISSUE:
Some 2011-2012 MKS, Flex, Taurus, MKT and Explorer vehicles built between 8/10/2010 and 08/02/2011 and some 2011-2012 Taurus SHO not equipped with the Performance Package built between 8/10/2010 and 8/02/2011 may exhibit a low frequency squeal from the front brakes.
ACTION:
SERVICE PROCEDURE
NOTE: PERFORMANCE PACKAGE SHO'S ARE NOT INCLUDED IN THIS PROCEDURE.
The Taurus SHO with the Performance Package is equipped with performance brake pads. Performance package Taurus's can be identified by SHO Performance Package - Performance brake pads, EPAS calibrated steering, ESC track mode/true off, 3.16 final drive ratio, 20" premium painted wheels with performance summer tire compound (P245/45YR) and tire mobility kit and is denoted by option code 12S.
NOTE: IF BRAKE DISC REPLACEMENT IS REQUIRED VERIFY IF YOUR DEALERSHIP IS ON THE DIGITAL IMAGING PROGRAM WHICH WILL REQUIRE PRIOR APPROVAL BEFORE REPLACING BRAKE DISCS. DO NOT REMOVE THE DULL GREY COATING ON THE NEW BRAKE DISCS; IT IS CORROSION PROTECTION.
NOTE: IT IS IMPORTANT THAT THE INNER AND OUTER BRAKING SURFACES OF THE BRAKE DISCS BE COMPLETELY CLEANED OF ANY METAL DUST, DIRT AND GREASE USING MOTORCRAFT® METAL BRAKE PARTS CLEANER AND A CLEAN RAG.
Measure the thickness of the front brake discs.
If the minimum thickness is over 28.5 mm (1.122") resurface them using an on-vehicle brake lathe, Refer to Workshop Manual (WSM), Section 206-00.
It is very important that all of the machining material has been removed from the front brake discs before installing the caliper and pads.
If the minimum thickness is equal to or less than 28.5 mm (1.122"). Replace the front brake disc, refer to WSM, Section 206-03.
Clean caliper anchor plate mounting surfaces, caliper anchor brackets and bolts of machining material. Refer to WSM, Section 206-03.
Replace the front brake pads. Refer to WSM, Section 206-03.
NOTE: FAILURE TO APPLY THE GREASE MAY RESULT IN UNACCEPTABLE BRAKE NOISE AT LOWER SPEEDS UNDER LIGHT BRAKING.
NOTE: GREASE SHOULD NOT BE APPLIED TO OTHER COMPONENTS LIKE PINS OR SHIMS. DURING BRAKE INSPECTION, LOOK FOR FOREIGN OBJECTS TRAPPED BETWEEN THE DUST SHIELD AND ROTOR. THESE CAN CAUSE NOISE DURING BRAKING AND OFF-BRAKE CONDITIONS.
BB5Z-2001-B Brake Pad Kit
CB5Z-1125-A Brake Disc
W715091-S439 Bracket Bolt
PM-4-A Motorcraft® Metal Brake Parts Cleaner
WARRANTY STATUS:
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
111029A 2011-2012 Taurus, MKS, Flex, Explorer, MKT: Machine Front Brake Discs. (Can Be Used With Operation C If Required). (Cannot Be Used With Operation B) 1.2 Hrs.
111029B 2011-2012 Taurus, MKS, Flex, Explorer, MKT: Replace Front Brake Discs (Can Be Used With Operation C If Required).(Cannot be Used With Operation A) 1.0 Hr.
111029C 2011-2012 Taurus, MKS, Flex, Explorer, MKT: Additional Time For Prior Approval If Required 0.3 Hr.
DEALER CODING
2001 42
- 11-10-27 FORWARD CENTER CONSOLE STORAGE BIN DOOR DIFFICULT TO OPEN
- 11-10-14 FRONT DOOR BLACKOUT TAPE WRINKLED OR BUBBLED - BUILT ON OR BEFORE 7/12/2011
- 11-10-9 OILY FILM ON INSIDE FRONT DOOR WINDOW GLASS
- 11-9-12 CREAK NOISE FROM FRONT BUMPER - BUILT ON OR BEFORE 9/6/2011
Publication Date: September 21, 2011
ISSUE:
Some 2011-2012 Explorer vehicles built on or before 9/6/2011 may exhibit a creak noise from the front bumper area while turning and/or negotiating grade changes.
ACTION:
Follow the Service Procedure below to correct the condition.
SERVICE PROCEDURE
Using a ChassisEAR®, verify noise is loudest at the front bumper beam.
If noise is loudest at the front bumper beam, proceed to Step 2.
If noise is not loudest at the front bumper beam, do not continue with this article. Perform normal diagnostics to identify the source of the noise. Refer to Workshop Manual (WSM), Section 100-04.
Replace the front bumper. Refer to WSM, Section 501-19.
BB5Z-17757-A Bumper Asy - Front
WARRANTY STATUS:
110912A 2011-2012 Explorer: Replace The Front Bumper Includes Time To Diagnose (Do Not Use With Any Other Labor Operations) 1.9 Hrs.
DEALER CODING
17757 42
- 11-9-13 2.0L GTDI - MIL WITH DTC P1289 AND/OR P1290]/color] - BUILT ON OR BEFORE 8/17/2011
[*]11-9-11 6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011
Publication Date: September 19, 2011
FORD: 2010-2011 Taurus
2009 Edge, Flex
2011 Explorer
LINCOLN: 2010-2011 MKS
2009 MKX
2010-2011 MKT, MKX
This article supersedes TSB 11-5-6 to update the Part List.
ISSUE:
ACTION:
SERVICE PROCEDURE
NOTE: IF THIS PROCEDURE IS NOT FOLLOWED CORRECTLY, ADDITIONAL NEW CUSTOMER SYMPTOMS WILL BE PRESENT, SUCH AS LOSS OF REVERSE OR 2-3 SHIFT FLARE.
For all model years except 2009, proceed to Step 2. For 2009 model year vehicles, verify the transmission dipstick has MERCON® LV listed on the dipstick.
Yes - The dipstick has MERCON® LV listed on the dipstick; proceed to Step 2.
No - The dipstick does not have MERCON® LV listed on the dipstick; this procedure does not apply. Follow normal Workshop Manual diagnostics.
Reprogram the PCM to the latest calibration using IDS release 73.04 and higher. This new calibration is not included in the VCM 2011.5 DVD. Calibration files may also be obtained at www.motorcraft.com.
Replace the separator plate in the valve body. The X identifies the hole in the valve body separator plate which will be eliminated. (Figure 1)
Figure 1 - Article 11-9-11
Figure 2 - Article 11-9-11
BT4Z-7Z490-B Valve Body Separator Plate
7T4Z-7Z490-D Valve Body Separator Plate
WARRANTY STATUS:
110911A 2009-2011 Edge And MKX: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.0 Hrs.
110911A 2010-2011 Taurus And Flex 3.5L DOHC, MKS And MKT 3.7L, 2011 Explorer 3.5L: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.0 Hrs.
110911A 2010-2011 Taurus, MKS, Flex, And MKT 3.5L GTDI: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.1 Hrs.
DEALER CODING
7A100 42
[*]11-8-3 BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE BLOCKAGE AND/OR DIAGNOSTIC TROUBLE CODE(DTC) - U3000 - BUILT ON OR BEFORE 3/29/2011
[*]11-7-25 INTERMITTENT LIFTGATE AJAR WARNING DISPLAYED IN INSTRUMENT CLUSTER WITH LIFTGATE CLOSED
[*]11-7-24 VARIOUS FUNCTIONALITY CONCERNS WITH MYFORD TOUCH AND MYLINCOLN TOUCH - BUILT ON OR BEFORE 7/12/2011
[*]11-7-21 COOLING FAN NOISE, LACK OF A/C AND/OR OVERHEAT CONDITION
[*]11-6-12 TRACTION CONTROL LIGHT ON - EQUIPPED WITH AUTO PARK - BUILT ON OR BEFORE 1/18/2011
[*]11-4-14 IKT OR IA - INABILITY TO UNLOCK DOOR - POSSIBLY INTERMITTENT - BUILT BETWEEN 7/1/2010 AND 1/26/2011
[*]11-4-12 INSTRUMENT CLUSTER MESSAGE CENTER - INACCURATE AVERAGE FUEL ECONOMY AND FUEL TRIP COMPUTER, COOLANT TEMPERATURE DISPLAY INTERMITTENTLY FLICKERS ON/OFF
Publication Date: April 15, 2011
ISSUE:
Some 2011 Edge and Explorer vehicles equipped with a base (single display) instrument cluster, may experience the average fuel economy with higher than expected values, fuel trip computer stops incrementing at 99.9 gallons, and the coolant temperature display intermittently flickers on and off.
ACTION:
Reprogram the instrument cluster to the latest calibration using IDS release 72.02 or higher. This new calibration is not included in the VCM 2011.3 DVD. Calibration files may also be obtained at www.motorcraft.com.
WARRANTY STATUS:
110412A 2011 Edge And Explorer: Reprogram The Instrument Cluster (Do Not Use With Any Other Labor Operations) 0.3 Hr.
DEALER CODING
10849 04
[*]11-4-6 NOISE FROM FRONT BOLSTER AT HIGHWAY SPEEDS - BUILT ON OR BEFORE 2/4/2011
[*]11-4-1 AWD - FALSE DTC P188D - BUILT ON OR BEFORE 2/24/2011
[*]11-3-26 LOWER VALANCE COMING LOOSE
[*]11-3-12 XLT - NOISE THROUGH FRONT SPEAKERS - BUILT ON OR BEFORE 2/7/2011
12-08-12 - ALL WHEEL DRIVE - FLUID LEAK FROM REAR DIFFERENTIAL VENT CAP - TEMPERATURES BELOW 0 DEGREES C (32 DEGREES F)
12-08-09 - 3.5L ALL WHEEL DRIVE (AWD) TERRAIN MANAGEMENT INOPERATIVE - BUILT ON OR BEFORE 7/30/2012
12-08-08 - 3.5L TI-VCT - FOUL ODOR FROM COOLING SYSTEM - BUILT ON OR BEFORE 7/9/2012
12-06-06 - TING POP NOISE - FRONT HALFSHAFT
12-05-11 - INTERMITTENT AIR BAG WARNING INDICATOR - BUILT ON OR BEFORE 2/5/2012
12-03-16 - 3RD ROW POWER FOLD SEAT - NOT LATCHING IN STOW POSITION AND/OR BOUNCES BACK - BUILT ON OR BEFORE 1/24/2012
12-03-11 - MULTIFUNCTION AND INFOTAINMENT DISPLAY SCREENS SIMULTANEOUSLY GO BLANK/SCRAMBLED IMAGES/FLICKERING DISPLAYS - BUILT 10/30/2011 THROUGH 12/31/2011
12-03-03 - POWER LIFTGATE OPENING - INTERMITTENT OPERATION - BUILT ON OR BEFORE 3/2/2012
12-03-02 - FRONT WINDOW GLASS JUMPS/CHATTERS DURING UP/DOWN TRAVEL
12-02-07 - TIN ROOF NOISE - FRONT ROOF AREA DURING RAIN - BUILT ON OR BEFORE 11/5/2011
12-02-06 - POWER LIFTGATE DOES NOT OPEN OR REVERSES AFTER OPENING APPROXIMATELY 25 MM (1 INCH)
12-01-11 - A-PILLAR TRIM RATTLE AND/OR BUZZ - BUILT ON OR BEFORE 11/21/2011
11-10-29 - FRONT BRAKES - INTERMITTENT SQUEAL
11-10-27 - FORWARD CENTER CONSOLE STORAGE BIN DOOR DIFFICULT TO OPEN
11-09-13 - 2.0L GTDI - MIL WITH DTC P1289 AND/OR P1290 - BUILT ON OR BEFORE 8/17/2011
11-09-12 - CREAK NOISE FROM FRONT BUMPER - BUILT ON OR BEFORE 9/6/2011
