kturnerga
- August 4, 2008
- GA
- 96 Ranger XLT 4.0 Ext cab
Hi
My 96 ranger has to have frequent correction of steering. I will turn the wheel left, for instance, and will travel straight until I need to turn it right. It seems as if the steering is hypersensitive. I wonder if something has a mind of its own. To fix this I did a change-out of the tie rods (rusted) and all that is left is from the Pitman arm on up. I did have it aligned though they had trouble fixing the camber adjustment at Sears. They also replaced a ball joint. Still the thing wobbles.
Would adjusting the steering box work or would tire rotation help? What are other possibilities?
Kt
Kt
