2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
I've heard that the 75mm throttle body for a Mustang 4.6L V8 might work on my Sport SOHC. My stock throttle body arm is a rotating round molded throttle cable guide.
There is small rod attached to the end of the throttle cable (perpendicular to the cable) that slides into a mating slot on the arm. (ignore the red arrows which point to the gap at the stop)
All the photos of 4.6L 75mm throttle bodies I've seen on the internet appear to have a different way of connecting to the throttle cable. I don't want to change my throttle cable or the way it connects to the throttle body. I want to be able to switch between the stock and 75mm throttle bodies.
Does anyone know of a 75mm throttle body (new or used) that is physically compatible with my stock setup? If so and new, who makes/sells it? If used original equipment, what make, model and year(s) of vehicle uses it?
