Does anyone know what size tires and lift is on this rig? Been searching around for the past few days with no results...thanks!
55.7 KB
Do you think there is any body lift in that? Doesn't really look like it, but I didn't think the 5.5'' lift could get you that much clearence on 35's....
hmmm...hard to tell isn't it, can't the bumpers be adjusted somehow? Most body lifts I've seen show a bigger gap than that, of course he may not have a very big BL on it, 1"...1.5"?
That's not a gap with the rear bumper, he cut the sheet metal up to that body line. The rockers cover a good portion of the frame; that's either camera angle or no body lift. If you follow the arch of the rear spring it looks like it's on top of the axle and you can see the radius arm drop brackets.
Are you sure those aren't just the stock radius arms with drops down brackets? I know 5.5 superlift kit doesn't come with new radius arms...but I do think those are skyjacker springs...
"Looking through his posts, he's got a 6" skyjacker and 3" body lift."
3 inches....really? Hmmm
Those are definitely Superlift arms. Stock are not that long.
So it's got a 9" lift using:
Superlift 5.5" lift w/SJ 6" coils
SOA (had OME leaf packs but went back to stock)
3" body lift
Also running:
Super Runner steering
ARBs
