From my manual:
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
- ² the parking brake is set
- ² the gearshift is in P (Park) (automatic transmission) or the neutral position (manual transmission).
- ² the ignition switch is in the OFF position
- ² all vehicle doors are closed
- ² the driver’s safety belt is unbuckled
- ² the parklamps/headlamps are in OFF position (If vehicle is equipped with Autolamps, the Autolamps feature MUST be turned off.)
To reduce the risk of injury, do not deactivate/activate the Belt Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1–2 minutes)
- ² Steps 3–5 must be completed within 60 seconds or the procedure will have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This can be done before or during BeltMinder warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled.
- ² After step 5 the safety belt warning light will be turned on for three seconds.
6. Within seven seconds of the safety belt warning light turning off, buckle then unbuckle the safety belt.
Seating and safety restraints
- ² This will disable BeltMinder if it is currently enabled, or enable BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by flashing the safety belt warning light four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by flashing the safety belt warning light four times per second for three seconds, followed by three seconds with the safety belt warning light off, then followed by flashing the safety belt warning light four times per second for three seconds again.
9. After receiving confirmation, the deactivation/activation procedure is complete
