Stic-o's F-250 Super Duty Crew Cab Lariat 4WD | Page 4 | Ford Explorer Forums - Serious Explorations
Wow I can't believe you have been this long without your truck. When you get it back check the bracket where the tracbar bolts to the axle. That bracket likes to likes to sheer at the weld to where the tracbar mounts will break right off the axle.
My truck has 130k and I have been chasing bump steer for awhile till found the crack. I had changed the ball joints, sway bar links and some steering links and still didn't see it. It finally found it doing an oil change and I rolled under the axle on a creeper and had my face almost touching the axle and noticed it. I had a 4" long crack in the bracket and you could barely tell. Luckly I cought mine for it broke all the way off. I'll google and post a pic of what I am talking about.
Happy to report the truck is back home now. :thumbsup:
I lost the Superwinch hubs I had just bought before the accident. But they replaced them with a brand new set of Warn ' s :D
Truck drives nice smooth.
Just received some new switches in the mail from otrattw. I'll be installing them and doing a write up soon. These are a test run for what I will be installing in JP in the future.
Switchs installed:D
..I just found a local company that sells these same customized switches..pick up in 24 hours..;)
Those would be cool in the bronco! What are your guys' sources?? When is the write-up? :D
..The card is in my truck...I'll get it tmrw and post..
These come from the bay area.;)
These are from between my house and your house..:p:
Installed some new goodies over the weekend.
New Stereo
Rear Camera ( you can see the ball for the hitch in the image:thumbsup:)
LED Bed light:D
Installed the aftermarket y pipe today.
You can see below the old exhaust was 2 1/2 inch and then necks down to 1 1/2 near the joint:eek:
The new is all 2 1/2
Just picked up some Torq lift frame mount tie downs off CL.:thumbsup: So the hunt will begin soon for the big part to go with it:D
I got to do this with the RV. Where you get the Y pipe?
Torq Lift camper tie downs installed :D
Does that mean you got a camper??
Not yet, still shopping. ;) I'm just planning ahead. Probably in the next 3 to 6 weeks.
The mounts work like a receiver hitch, and have a hitch pin so the ends slide out and store away when not in use.
