Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
misfire and hesitation in open or closed loop... no o2 voltages
Reply
Thread Tools
Old 06-04-2012, 11:22 AM   #21
xploder98
Hemet, Ca
1998 Sprt 2wdr
Vehicle Specs
(Original Poster)
Well, time to start takin er apart. Just Down to injectors. I'll Ultrasonic clean them and my rail, the change out gaskets, retorque head studs while its all off, and somethin i been wantin to do for a while is pressurize my plastic upper manifold and check for leaks. Will let u guys know wut happens. Btw thanks for everyones input, help, and ideas. This site is probably the reason the majority of us still have our explorers. If theres ever a question to ask i come here! And the help is always appreciated! Thanks
xploder98 is offline   Reply With Quote
Old 06-04-2012, 06:32 PM   #22
xploder98
Hemet, Ca
1998 Sprt 2wdr
Vehicle Specs
(Original Poster)
What can cause the timing to go from 9.5 degrees to 19 within 75 rpm? Bad crankshaft position sensor? i know how to test it but its kinda impossible for me since I'm doin all this by myself. I cant crank the engine and hold volt meter under the radiator. My arms aint long enough
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
1994 Ford Ranger misfire and hesitation - really need help danmm7 Stock 1991 - 1994 Explorers 5 03-12-2012 11:37 PM
Possible to change 4.6L rod bearings with engine in vehicle? jayton Stock 2002 - 2005 Explorers 5 08-24-2011 01:52 AM
Misfire and Hesitation.....1994 X backfrmcolorado Stock 1991 - 1994 Explorers 4 05-25-2011 09:35 PM
My 1996 Explorer has hesitation with an occasional misfire. angelsrule Stock 1995 - 2001 Explorers 5 11-10-2010 11:16 PM
Replaced VCGs, now stumbling, misfire, hesitation, etc. sethmorgan Stock 2002 - 2005 Explorers 3 06-25-2008 08:13 PM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
