mustangluv
- July 22, 2014
- jefferson city, missouri
- 98 explorer
Hello all,
recently I replaced the motor out of a 98 I picked up really cheap. I found another motor out of a 98 and replaced the two timing chain tensioners. The one on the rear and the one on the top of the motor. I got in it after the install and it started up sounded good! But driving it home it started rattling and running rough. And at low idle it seems to want to die. My question is, is it possible to put the tensioner in too tight that it makes the chain bind a bit? Or does it sound like something worse? As i rev the engine the noise gets worse.
