xTOM153x
- October 28, 2009
- West Islip Long Island
- 2003 XLT
First to let everyone know I have a 2003 Ford Explorer 4.0L 4dr. I have a borg warner 4411 transfer case 2 speed elec shift. The transfer case is a reman unit from Transmission Authority which is a company that sells reman units through rock auto. The transfer case is a little under a year old so its leading me to believe that it is not the problem. The problem I am having is when only in 4WD and when you are turning the wheels does a very loud cracking noise/banging noise happen. This happened on a very slippery surface so it is not axle bind or w/e you call it. I thought maybe it was the CV axles so I replaced them since they were under the lifetime warranty. Turns out that was not the problem. Next I checked the front differential. I thought maybe something happened with the ring and pinion its been about 6 months since i had 4.11's installed. Turns out everything checked out 100% in there. Next I pulled the front driveshaft. No more cracking/banging noise in 4wd but I saw that coming since it seems like its only under a load with the front tires. I checked the propeller joint it seems ok i guess? I really don't know how to tell if its bad it seemed fine. No cracked boot and grease inside no contamination. I spun the transfer case flange that powers the front and it spins freely in 2wd. Once i put it in 4wd it locks up since the rear DS is not moving but then if i rotate the opposite direction it will unlock then lock up so i'm wondering is that normal? could the transfer case be at fault here? How do i diagnose this 4wd works fine just makes that crazy loud noise sounds like something is going to break! Could it be the front driveshaft propeller joint? I eliminated the front axles and diff what else could it be?
