| 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Home | Register | Members Rides | Vendors | Top Posters | FAQ/Rules | Social Groups | Search | Today's Posts | Mark Forums Read |
| Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum. |
Thread Tools |
#1 |
Wannabe Elite Explorer
milford
2002 xlt
code p1131
I changed valve cover gaskets and intake gaskets on my 2002 Explorer with a 4.0. I get everything put back together and the truck idles great. Ten minutes later the truck starts skipping while in park and you can drive the truck with no problem till you come to a light. So i plug in my scanner and I get a code of p1131 but no engine light comes on. Has anyone else had this issue and I know what the code is but I am at a loss for why I got this code.
#2 |
Kansas City, MO
2004 Limited
P1131 Lack of Upstream Heated Oxygen Sensor Switch-Sensor Indicates Lean-Bank No. 1\
Any chance you accidentally loosened a sensor plug somewhere in the area surrounding where you were working? Did you triple-check that everything got plugged back in? Can you verify that you properly installed the gaskets you replaced? |
#3 |
milford
2002 xlt
I will triple check the connections again. I may have to take the intake off just to verify the gaskets are ok,but they should be fine.
#4 |
milford
2002 xlt
I now have a code p0174. Left bank to lean
#5 |
milford
2002 xlt
Problem solved.It turned out one of the electric connectors on the back of intake had two rubber spacers in it so it could not connect properly.
| Suggest this thread to friends: |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| All you need to know about keyless entry | Xan | Stock 1995 - 2001 Explorers | 321 | 05-19-2013 02:52 PM |
| 92 Ranger Keep alive memory code 512. | congaman | EEC IV | 6 | 06-09-2009 08:51 PM |
| code p0340, replaced camshaft sensor, still throwing a code, A/C related??? | Zmuzic | Stock 1995 - 2001 Explorers | 1 | 12-07-2007 02:36 AM |
| engine codes with code reader | LS431o28 | Under the Hood | 2 | 12-20-2001 12:04 PM |
| Thread Tools | |
