Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Intermittent "Rub" Noise?
Reply
Thread Tools
Old 07-16-2012, 03:55 PM   #1
03ExploKRV
2003 XLT V6
Vehicle Specs
(Original Poster)
I've noticed twice now a sort of "rubbing" noise/vibration coming from my 2003 Explo V6, 4x4. This only seems to happen after driving the truck for a long distance.
The first time it happened, my niece felt it in the rear of the vehicle and asked "what was that..." I did not hear it any longer that evening. It happened while getting back on the gas, at low speed, while turning right.
The second time this happened was last Friday. It felt like it was coming from the left front wheel. It felt as though the tire was rubbing on something???
I'm thinking maybe left front wheel bearing issues? The truck shifts and runs fine 99.9% of the time. This just started a few weeks ago and as you can see from above, is very intermittent.
Anyone have any ideas what to check or how to check what could be bad? Could u-joints bad also cause this type of situation/feeling? All four tires are the same also in case someone was going to bring that up.
Thanks, guys, in advance!
Oh, another thing. Can anyone tell me a cheap way (not going to dealer) to figure out what backup sensor might be bad? I was going to tear down the rear bumper and just start replacing the sensors but if I could find the exact one that's bad it might be better on the nerves! Is it difficult removing the bumper cover on the rear???
03ExploKRV is offline   Reply With Quote
Old 08-12-2012, 04:44 PM   #2
kifferarri
02ExplorerXLT 87MustangGT
Vehicle Specs
I'm having a similar noise problem, mine is a little more consistant tho. I just bought the truck (02 XLT 4x4), and figured it had been the rear diff clutches chattering, but after changing the fluid (75w140 and ford friction modifier) I still have a rubbing noise, only when turning and accelerating after a stop... and the harder i listen, the more I'm convinced it is the front...
__________________
87 stang GT 5.0, many mods, many more to come >D muh hahahahaaa!
94 exploder 4x4 xlt, sold
02 exploder 4x4 v8 xlt, flex-a-lite electric fan, k&n cold air
"I'm mechanicaly inclinded... but not inclinded to be your mechanic..."
kifferarri is offline   Reply With Quote
Old 08-12-2012, 07:38 PM   #3
TimB
walpole, MA
2003 Limited V8
Vehicle Specs
Left front hub would be my guess!
I had a similiar noise, it was the left front hub. There is a 16 page sticky write-up on how to replace them.
TimB is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
OBD-II Diagnostic Trouble Codes (DTCs) BobWiersema EEC V 8 03-26-2013 10:22 PM
10 commandments The exploder Explorer Audio & Navigation 10 07-13-2012 11:42 AM
Popping noise after transfer case rebuild ??? divepro99 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 11 07-30-2010 01:00 AM
Noise when Braking skidoomxz99 Stock 1995 - 2001 Explorers 4 10-14-2009 05:26 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
