Bapster
- November 21, 2012
- 1999 Ford Explorer XLT
Hi all,
I replaced the reverse band in my 99 explorer xlt as it had broke, and I got a seal and gasket kit and replaced the seals and gaskets that I could, all the other internal parts were good, as all my forward gears worked perfectly, just didn't have reverse suddenly which is why I replaced the reverse band. Now my issue is I have a delayed reverse, about a 3 second delay and I apparently have a 1-2 shift flare, manual 2nd gear works fine when shifted on the column, but it doesn't want to shift out of first on it's own...planning on trying another band adjustment, I think I read on here that the o/d band also controls 2nd gear correct? we also changed both of the vb gaskets that came in the kit, Any other ideas for me to check/look into? Thanks guys, I appreciate the help....reading on this site helped me alot with replacing that reverse band...so thank you for that as well
- Brian
- Brian
