EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
HELP Removing Rear Knuckle
Reply
Thread Tools
Old 02-12-2009, 03:46 PM   #1
joefnh
New Hampshire
03 XLT
Vehicle Specs
(Original Poster)
I have a 2003 Explorer with a 4.0L V6 4x4 and I am in the process of removing the rear knuckle to have the wheel bearing replaced.
As I am trying to remove the 3 ball joint mount points, I have to remove the pinch bolts. On what would be the head of the bolt, is a square head that cannot rotate due to a nearby flat on the knuckle housing. The nut came off OK but I cannot take the bolt out.
I am assuming that I need to remove the pinch bolt fully to be able remove the upper control arm ball joint. I have banged on the end of the bolt with a brass rod quite hard and the bolt will not budge at all.
Any ideas? Do I have to remove the bolt fully? I am assuming that the bolt shaft actually helps captivate the shaft of the ball joint.
Thanks in advance
--Joe
joefnh is offline   Reply With Quote
Old 02-13-2009, 07:43 AM   #2
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Correct. The three bolts in question slide through a groove machined into the ball joint to help retain them in the event the bolt loosens or the head breaks off. As long as the remaining piece doesn't fall out, the joint will be retained in the knuckle... loose, but retained.
This is one of those cases where you just need a bigger hammer. If you have them, place the brass hammer on the bolt, then whack it with a heavier 4-lb baby sledge or something similar. They're likely just corroded to the knuckle, that's all.
Also, make sure your CV joint stub that sticks through the bearing/hub assembly is loose. It's much easier to pop it through before you have the knuckle dangling in mid-air.
-Joe
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 02-13-2009, 04:41 PM   #3
joefnh
New Hampshire
03 XLT
Vehicle Specs
(Original Poster)
Thanks Joe, it did take a "bigger hammer" it took the combination of a 5lb mini sledge and a acetylene torch to get those pinch bolts out.
Now before I re-assemble the knuckles do I have to replace the pinch bolts with new ones? How about the axle nuts?
In looking into the Haynes manual I cannot find a torque spec for the axle nut, does anyone know what it is (for both the rear and from axles)
--Joe
Old 02-13-2009, 06:45 PM   #4
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
If it was mine, and I had to heat them and pound them out, I'd probably replace 'em. You can probably get away with re-using them though.
Can't help with the torque spec before Monday though... The manuals I have at home are only through '01... sorry. Maybe someone else on here has an '03 manual?
__________________
Old 02-13-2009, 06:59 PM   #5
joefnh
New Hampshire
03 XLT
Vehicle Specs
(Original Poster)
Thanks Joe, do you have to replace the axle nuts?
What would happen if the axle nut was over torqued? especially on the front axles. I had replaced those recently but had to guess on the spec .
--Joe
Old 02-13-2009, 07:38 PM   #6
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Officially, the word from Ford is yes. They're a squash-nut and only designed to be used once. However....
Lots of people on here have re-used them, myself included. Not sure offhand what the torque spec is on that either, but IIRC, the front for my 98 was around 200 ft*lbs.
Over-torquing the fronts could result in a stripped nut, stripped threads off the CV shaft, or both. That's about it. It's not, however, going to hurt the bearing (provided it doesn't loosen up due to being stripped). The way the hub is designed, the clamping force from the spindle nut clamps the inner 'race' against a shoulder on the outer flange. It's a hard stop, so no matter how tight you make it, it's not going to overload the bearings.
-Joe
__________________
Old 02-13-2009, 07:48 PM   #7
joefnh
New Hampshire
03 XLT
Vehicle Specs
(Original Poster)
Thanks Joe that good to know. I suspected that the nuts could be reused.
I did find out on the following website that the torque spec for the front is 184 ft/Lbs
http://cds.activant.com/C2C/C01/35/192/157591741.pdf
Another website listed the rears at 203 ft/lbs for a 2002 explorer
Thanks again
--Joe
Old 02-14-2009, 04:09 PM   #8
goatman
Oakdale Tn.
goatman's Avatar
'05 XLT V8
Vehicle Specs
The thing that helped me out the most was PB Blaster. I soaked the nuts and the joints over night. The next morning, the nut came off the stud easily and the bolts needed very little beating to back out. The tuff part was getting the joints to let go of the knuckle. Even after much soaking, lt took a lot of vibration with a short sledge and a wood block to get them loose. And I when I got the uppers loose, I found it easier to remove the rear alignment bar still attached to the knuckle and put it on the work bench to get the lower joint loose. Then, Good or bad, before I re-installed the knuckles I coated the joints with anti-sieze (sp??).
__________________
Mike (goatman) Henry
05' XLT 4x4 V8. 2" RoadBully Spacers (Front), 275/70/16 Yokohama's, Edlebrock RPM series muffler with 2 1/2" exhaust. K&N Filter
91' F150 4x4 351 XLT Lariat
94' XL, 4.0, 5 speed, 2" bl, 32x11.50(sold it )
goatman is offline   Reply With Quote
Old 02-14-2009, 05:49 PM   #9
joefnh
New Hampshire
03 XLT
Vehicle Specs
(Original Poster)
Goatman thanks for the reply. I too use PB Blaster quite liberally and most of the time it does help. In this case it still required quite a bit of hammer work. I did also leave the alignment ball joint attached until after I removed the knuckle, then removed it while holding it in a vise
Again Goatman good advice.
Thanks to both Goatman and gijoecam, I just finished the job a couple of hours ago and all went well with the re-assembly. Joe I did replace the pinch bolts as suggested. Its good to have a quiet truck again, it rides great.
Thanks again
--Joe
Old 05-21-2012, 05:20 PM   #10
ndreaves
Spring Hill, Florida
2004 Explorer Eddie Bauer
Vehicle Specs
Removing rear knuckle on 4X4.
AllData shows 150nm (111 lb-ft) for tightening the pinch bolt lock nut. Another thing, using PB Blaster in the pinch slot will help tremendously in removing the pinch bolt. Always leave the locking nut on the bolt, loosening it to be even with the bolt end. (saves the bolt threads).
CORRECTION to the above. The 111 lb-ft is for the lower pivot. The ball joint pinch nut is 90nm (66 lb-ft)
ndreaves is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
