corey.p
- August 29, 2015
- st.louis
- 1991 ford ranger
Hello, I just bought my first truck a 1991 Ford ranger automatic v6 for $300.the problem is when when you put it in reverse it locks up In neutral you can't push it back ether .I was told when you Jack the rear end up it will work fine with out the weight of the truck on it .I also noticed when I first turn on the key a light comes on dash that's says rear anitilock. The truck came w a New (used) rear end I also know a good tranny guy but if I can fix it with out putting a bounch of money in it that'd be grate ..so any advice would be grate , thank you
