#1 Resource for Ford Explorer and Ranger Owners - By Enthusiasts, for Enthusiasts.
EF Swag Store 2015 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2000 Explorer with cracked porcelain on a spark plug.
Reply
Thread Tools
Old 10-29-2009, 11:34 PM   #1
jzvosechz
2000 xlt 4.0 ohv
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2000 explorer with a 4.0 ohv motor. the number 4 cylinder keeps coming up with a misfire code. When the plug is removed the porcelain inside the head is cracked and half of the porcelain is missing. Have changed the plugs and wires the first time and just the plug twice after. Have also removed all injectors and soaked them in carb cleaner over night. The injectors were then reinstalled with new o-rings. It takes about 100 miles before I notice a rough running condition and the check engine light comes on again. The code only comes up for cylinder four. All plugs look to be firing ok, even number four on the half of porcelain left (no carbon build-up,no discoloration-not orange like lean not green like coolant leak) have asked many people no one is sure about path to follow to resolve
jzvosechz is offline   Reply With Quote
( Join the Elite Explorers )
For only $20 per year you can become an Elite Explorer. Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn what modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to see less ads, no green underlined links, and many other benefits such as being able to store 1000 Private Messages, upload photo attachments directly to your posts and more. Join the Elite Explorers today.
Old 10-30-2009, 11:20 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 121 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section. Do you know what the code number is?
BrooklynBay is offline   Reply With Quote
Old 10-30-2009, 11:33 AM   #3
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL Pumpkin Edition
Vehicle Specs
Quoted: 130 Post(s)
Possibly a lean condition in that cylinder causing detonation which breaks the ceramic. that's all I can think of...
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
1960 Dodge Dart Seneca
Rick is online now   Reply With Quote
Old 10-30-2009, 11:50 AM   #4
coonerboy
Herkimer, NY
98 Explorer XLT 4wd V8
Vehicle Specs
Quoted: 0 Post(s)
Did the broken porcelain piece fall into the cylinder? If it did that could be a big problem.
Are you saying you are on your 3rd plug for the #4 cyl? It keeps breaking after you put it in?
__________________
'98 Explorer XLT V8 4wd 100kmi. 4406 t-case, MAC intake and catback exhaust.
coonerboy is offline   Reply With Quote
Old 10-30-2009, 12:10 PM   #5
corkey
New Member Moderator,
will the snow ever end ?? Welcome,,
corkey's Avatar
96xl,99xls,old Rangers
Vehicle Specs
Quoted: 42 Post(s)
hmmm they are resistor plugs, so it will not fire properly with 1/2 the porcelain missing, replace the plug,,
__________________
Log Roller,, Fox Coilovers 35's and others, ,
Truck of the month
Ranger Of Danger,,,project truck,
also look for Blues Traveller Elite registry, ,
corkey is offline   Reply With Quote
Old 10-30-2009, 12:43 PM   #6
coonerboy
Herkimer, NY
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Right on corkey! The high energy spark WILL seek the path of least resistance. I have seen spark go through hairline cracks in spark plugs. Change the plug. If it keeps cracking after you put it in, figure out why it keeps doing that. Good luck.
__________________
Old 10-30-2009, 05:48 PM   #7
GCDMD
Minden, NV
99 Limited V8
Vehicle Specs
Quoted: 0 Post(s)
The man's dead on. I actually went through this problem on my 97 SUHC...I mean SOHC. There was a hairline fracture that wasn't visible unless a bright light was near it. That small fracture was enough to cause a P0171 code and a severe miss at idle and load. I would recommend replacing all of the plugs at the same time. Another thing to add: make sure there are no "gaps" in the porcelain. Gaps indicate the porcelain fractured and separated- possibly in your block. That is when it gets scary.
Forgot to mention that I have received a cracked spark plug from the store. Carefully inspect every plug before inserting into your engine, regardless if it is new or old!!!
__________________
1999 Limited 5.0L
GCDMD is offline   Reply With Quote
Old 10-31-2009, 09:01 AM   #8
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 130 Post(s)
He needs to find out why the plug keeps breaking each time he installs a new one... I stick by the lean condition causing detonation in that specific cylinder...
__________________
2004 Mustang Mach 1
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2014 - 1996 Rick Horwitz Photography
