2quick2draw
- November 12, 2013
- 86 ford bronco 2
i have an 86 bronco 2. when its cold it will start and run till it warms up then it quits. starts when u floor the gas pedal and crank the engine. like when the engine is flooded. pulled the plugs and they are black. changed the fuel pump, fuel filter,fuel regulator, plugs, cap and rotor, and wires. this thing has been sitting for about 1 year due to a bad fuel pump. fuel pressure is 55psi with the key on. Any body have any ideas of what to check next.
