9EXNY
- October 16, 2011
- NEW YORK METRO
- '08 EXPLORER XLT
6 yrs from manufacture date.
That would be a DOT code ending with "08".
Looks great, hope you enjoy them as much as I've enjoyed mine.
Just noticed you're in Fredericksburg; you should come out the next time we run the trails at GW National Forest. Couple of us drive right thru Fredericksburg on our way out there.
I'm planning to get some 285's with 3" body lift and front rancho quick lift,
you thing will be good clearance ? or maybe add some 1-1-2/2' wheel spacer ?
If they're going on your stock wheels i am pretty sure you will have to do a wheel spacer. not because of tire to fender clearance but because the 285 is wide enough to rub on the steering knuckle if you don't push it out from the hub some.
