Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2007 - 2010 Explorer Sport Trac
Notices
2007 - 2010 Explorer Sport Trac All questions about the stock 2006- 2010 Ford Explorer Sport Trac.
A/c problem
Reply
Thread Tools
Old 04-08-2012, 09:38 PM   #1
Gbh1124
Jackson ms
2007 sportstrac
Vehicle Specs
(Original Poster)
A/c problem
I have 2007 v6 with 46547 miles. It just started acting up in the last 2weeks. When I accelerate slightly or aggressively it shuts the blower motor off or seems to. As soon as I lift out of the throttle blower motor blows again. It has never done this before in the 5 years I have owned it. I have heared about computers that shut a/c off for power reasons. I don't believe this is what is happening with mine. Is the a/c & heater system controlled by vacuum or electrically with actuators . What is my fix???
Gbh1124 is offline   Reply With Quote
Old 04-16-2012, 09:11 PM   #2
Gbh1124
Jackson ms
2007 sportstrac
Vehicle Specs
(Original Poster)
With all the sports trac owners on here it is amazing that I am the only one to know or have this a/c control problem? Come on people some help please!!!
Old 04-16-2012, 10:42 PM   #3
moar_swimps
H-Town, Texas
2007 Sport Trac XLT 4.0
Vehicle Specs
I'm having the same problem with my 07 ST with 104000 miles... getting it looked at this week... I think it may be a vacuum problem.
Idk if you may have this other little problem but when I accelerate, it makes a little whistle sound till about 2000rpm...
moar_swimps is offline   Reply With Quote
Old 04-17-2012, 05:11 PM   #4
STrac4me
Bonneau, South Carolina
2007 Sport Trac Limited
Vehicle Specs
My blower does not slow down, but the temperature varies (warms up) if I accelerate hard. I would think that would be normal. What you describe would not be normal, but have never heard of this before.....good luck with your problem!
__________________
2007 Explorer Sport Trac Limited, 4.6ltr, 6 speed auto, K-Cover Hard Tonneau, Pioneer AVH-3300BT, Rockford Fosgate 300X1 mono amp, P2 8" sub....
SOLD 2005 Explorer Sport Trac, Pioneer Premier 700BT, Sirius Sat Radio...The rest Stock for Now!
STrac4me is offline   Reply With Quote
Old 04-17-2012, 10:08 PM   #5
Snap65
Southern, Indiana
2007 Sport Trac XLT
Vehicle Specs
Sounds like you got a vacuum leak. Mix soap and water, then use a spray bottle to spray it on your vacuum lines. Small bubbles will let you know if you got a leak.
Snap65 is offline   Reply With Quote
Old 04-18-2012, 06:46 PM   #6
Gbh1124
Jackson ms
2007 sportstrac
Vehicle Specs
(Original Poster)
Quote:
If I have a vacuum leak,I don't believe soapy water will show it? Because vacuum leak would be sucking the soapy solution into the vacuum line. Is this not correct??? You will need pressure not vacuum for bubbles to show up.
Old 04-18-2012, 07:18 PM   #7
Snap65
Southern, Indiana
2007 Sport Trac XLT
Vehicle Specs
Quote:
Wait... you're right, I was buzzing when I posted this and wasn't thinking straight. Sober now and thinking about it, soapy solution might be bad for the engine. I would use something that burns like brake cleaner. Listen for a jump in the idle's and that's where you're leak will be.
Old 05-02-2012, 03:35 PM   #8
BARtruth
Dyersburg, TN
2008 Sport Trac XLT
Vehicle Specs
A/C Problem
I have the same problem with my '08. It doesn't do it every time though. It happened several times today but accelerating when the speed was over 60 it did not happen. I was on a trip and when I got back near home it worked perfectly at all speeds.
BARtruth is offline   Reply With Quote
Old 05-03-2012, 05:33 PM   #9
Gbh1124
Jackson ms
2007 sportstrac
Vehicle Specs
(Original Poster)
More details
I made a long trip this past weekend. I found that the blower motor was not shutting off,but the air flow was changing on it's on to defrost as soon as I eased out of the throttle it went back to the dash vents. I now am quite sure I (we) have a vacuum problem. I found the control switch for a/c,vent,or defrost on carquest's website. It has an electrical connection & a vacuum connection. I am thinking about buying it & trying to see if this fixes my problem.what y'all think? It only cost $20.00.
Old 06-11-2012, 10:23 AM   #10
Gbh1124
Jackson ms
2007 sportstrac
Vehicle Specs
(Original Poster)
Problem solved
I have the fix for my a/c problem. Look under hood on passenger side at fire wall. You will find 2 vacuum lines 1 grey & 1 black. Follow the black one back towards the engine for about a foot,you will find a black & white check valve. Replace it paying attention to its direction of flow. I lost my invoice with part number but it is called a vacuum check valve. Cost $10.00.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
A/C Problem... I think? Twentybinders Stock 1995 - 2001 Explorers 4 03-01-2011 11:53 AM
A/C cluch problem? Help! JohnnyS 2001-2005 Explorer Sport Trac 3 11-25-2010 05:15 AM
A/C Light Problem 2004 Explorer tedmundson Stock 2002 - 2005 Explorers 1 04-28-2009 11:49 AM
New member, Stumped by A/C problem Toolguy942 Explorer, Ranger, A/C & Heater systems HVAC 6 11-14-2008 06:22 PM
02 Explorer - Wet Floors A/C problem? More? ScubaDave Explorer, Ranger, A/C & Heater systems HVAC 5 10-01-2007 10:14 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
