#1 Resource for Ford Explorer and Ranger Owners - By Enthusiasts, for Enthusiasts.
EF Swag Store 2015 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
how to tell if a spark plug is not working?
Reply
Thread Tools
Old 05-04-2006, 08:05 PM   #1
JatZilla
Central NJ
'98 4.0L SOHC, 4WD EddieB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Angry how to tell if a spark plug is not working?
I was able to change only 2 spark plugs on my 98 explorer so i had a local mechanic change the other 4. After 2 days, check engine light came on and the engine started running rough.
how can i diagnose this? how can i determine if one - or more - of the plugs isn't working? side issue...i can't believe how hard a couple of the plugs are, to reach.
TIA
JatZilla is offline   Reply With Quote
( Join the Elite Explorers )
For only $20 per year you can become an Elite Explorer. Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn what modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to see less ads, no green underlined links, and many other benefits such as being able to store 1000 Private Messages, upload photo attachments directly to your posts and more. Join the Elite Explorers today.
Old 05-04-2006, 08:19 PM   #2
ajr2000
Trumbull, CT
ajr2000's Avatar
93 XLT
Vehicle Specs
Quoted: 0 Post(s)
What I used to do on lawnmowers was take the plug out connected to the wire and just ground the plug to the engine, but outside of the engine so you can see it. Just be careful that you don't screw up the gap.
ajr2000 is offline   Reply With Quote
Old 05-05-2006, 09:03 AM   #3
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
if its not working.... typically when you pull the plug, it will be wet meaning that the gas is not being burnt. You can check the wiring / plug as suggested. If you have an induction timing light, clip the light on the "suspect lead", if it triggers, that will tell that the spark "signal" was at least sent.... and should have made it to the plug assuming there aren't breaks in the wire, poor connnect at the cap snap on, or cracks in the plug.
Ultimately, get the codes read, they will help you eliminate a lot of stuff quickly.
budwich is offline   Reply With Quote
Old 05-05-2006, 09:05 AM   #4
JatZilla
Central NJ
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
just so i get this right...touch the outside of the plug to some part of the engine, then crank the starter to see if it sparks?
Old 05-05-2006, 01:28 PM   #5
DCExplorer
Accokeek MD
98 EB
Vehicle Specs
Quoted: 0 Post(s)
Another trick is to simply pull each plugwire one at time. I you pull off a plugwire and the truck runs worse, chances are the plug is firing. However, if you can find a plugwire where the truck runs exactly the same whether it is attached or not, then that cylinder is likely the one giving you a problem.
__________________
1998, 5.0L V8 (302 c.i.), All-wheel Drive (AWD), Eddie Bauer
Hidden Hitch class III, Rancho 9000 shocks, PowerSlot Rotors, Hawk Pads
DCExplorer is offline   Reply With Quote
Old 05-05-2006, 01:48 PM   #6
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 1 Post(s)
1st thing I would do would be to pull the codes from the computer. EEC-V can identify misfires, often can pinpoint which cylinder(s), and otherwise give you a good place to start.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2014 - 1996 Rick Horwitz Photography
