Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > Stock 2011 - 2017 Ford Explorer Discussion
Notices
Stock 2011 - 2017 Ford Explorer Discussion 2011 - 2017 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
How to reset the Oil Monitor sensor
Reply
Thread Tools
Old 06-23-2011, 07:00 PM   #1
cbx1047
waikesha, wisconsin
2015 limited
Vehicle Specs
Quoted: 20 Post(s)
(Original Poster)
resetting oil life
I just changed my oil at 4700 miles, and wanted to reset the oil life monitor. I have a limited and the owner manual stated to go to system and oil life and reset. I did that and when I pushed the OK it just went to the next system check item?!@#$. whats up? How can I reset it to 0%?
cbx1047 is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-23-2011, 07:28 PM   #2
sm4astan
Holland Patent, NY
2011
Vehicle Specs
Quoted: 0 Post(s)
Just did my first oil change a few weeks ago and it took me forever to figure this out. I'm still not sure the exact steps, but it's in the left LCD menu and not the one you are looking at.
I'm sure someone will post here before I next am in my X (pouring rain outside now). But play in the left LCD screen, and you will find it. It's obvious because you will see a reset option.
sm4astan is offline   Reply With Quote
Old 06-24-2011, 06:01 AM   #3
GWA1
New Castle, DE
2011 Explorer Limited AWD
Vehicle Specs
Quoted: 3 Post(s)
Quote:
push and hold down until it resets
__________________
"Always do right. This will gratify some people and astonish the rest."- Mark Twain
GWA1 is offline   Reply With Quote
Old 06-24-2011, 06:10 AM   #4
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Vehicle Specs
Quoted: 112 Post(s)
As a side note, I also always clear the Trip #2 since I use this to easily and quickly give me an indication as to the number of miles on that oil change. I use Trip #1 for miles between gas fill ups.
Bill #5 Explorer is offline   Reply With Quote
Old 06-24-2011, 06:53 AM   #5
sm4astan
Holland Patent, NY
2011
Vehicle Specs
Quoted: 0 Post(s)
Just had to run out for milk so checked this. Here's the proper path -
Settings > Vehicle > Reset Oil Life (it's almost the last option)
Then just select what % you want to set it to.
Old 06-24-2011, 06:56 AM   #6
GWA1
New Castle, DE
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Ditto
__________________
Old 10-04-2011, 08:36 PM   #7
jonmichael
Brentwood, TN
2011 Limited
Vehicle Specs
Quoted: 0 Post(s)
Reset Oil Life indicator
I have a 2011 Ford Explorer Limited with MyFord Touch. I just had my first oil change at 4800 miles ( the system did not indicated I needed one, but the car is 7 months old and I try to stay on a 5k mile or 6 month max ). When I picked the SUV up at the dealer, the oil life indicator was still showing 45%. The oil life indicator is located on the left panel ; you can navigate to this indicator by going to Information > System Check > Oil Life.
The service writer was not able to tell me how to reset this function.
I assume you need to reset if you are going to reset when the computer will indicate the next oil change. I have read the owners manual ( and cannot find any clues on how to reset this function ). Can anyone help step me thru the steps to reset oil life indicator function ?
jonmichael is offline   Reply With Quote
Old 10-04-2011, 09:01 PM   #8
1995E
Maryland
95 + 11 Ex both XLT
Vehicle Specs
Quoted: 240 Post(s)
To reset it. Go to Information > System Check > Oil Life. All you need to do is hold the OK button on the left part of the steering wheel. Then a little blue bar should show up. Wait for it to finish loading by holding the OK button and you're done. 100% should show up.
__________________
Used to have an Explorer 1995 4.0L V6 XLT Only 70K miles.
Explorer 2011 3.5L V6 XLT 202A with trailer tow, Ingot Silver 15k miles.
2013 Ford Fusion Titanium with 50 miles.
1995E is offline   Reply With Quote
Old 10-05-2011, 09:21 AM   #9
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Vehicle Specs
Quoted: 112 Post(s)
Settings
Vehicle Setting
Oil Life Reset
Select 100%
Hit OK
All done with the left side LCD. We just discussed this a few days ago.
Old 01-19-2012, 09:33 PM   #10
Fredridge
Los Angeles, CA
2011 Explorer
Vehicle Specs
Quoted: 3 Post(s)
Oil life monitor
Does it just monitor your driving or is there an actual oil sensor?
Had my oil changed last month and the oil change reminder just popped up?
If no actual sensors, can I reset it myself?
Fredridge is offline   Reply With Quote
Old 01-19-2012, 09:56 PM   #11
cnsheets
2011 Explemoner
Vehicle Specs
Quoted: 0 Post(s)
Was it reset when the oil was changed? Seems a bit soon to go off again.
cnsheets is offline   Reply With Quote
Old 01-19-2012, 10:50 PM   #12
Fredridge
Los Angeles, CA
2011 Explorer
Vehicle Specs
Quoted: 3 Post(s)
Quote:
I don't know. I am guessing it wasn't, been less than 1000 miles.
So either it wasn't reset or they didn't change the oil.
Old 01-19-2012, 11:12 PM   #13
cnsheets
2011 Explemoner
Vehicle Specs
Quoted: 0 Post(s)
Could have changed it and just not reset it. I would just reset it.
Old 01-20-2012, 07:54 AM   #14
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
Vehicle Specs
Quoted: 112 Post(s)
Quote:
Yes. Reset with the controls on the left side LCD screen. You should select something less than 100% when you do the reset since you have driven about 1,000 miles already. I suggest 90%.
I also use the Trip 2 odo to keep track on miles driven on the oil change. After an oil change I make sure the oil life indicator has been reset to 100% and clear the trip 2 screen.
I am running full synthetic and changing at about the 7,000 miles mark. A little early. About 75% expired, or 25% remaining.
Old 01-20-2012, 08:10 AM   #15
RandyH2
MI
'11 Limited AWD
Vehicle Specs
Quoted: 25 Post(s)
Can someone verify that there is actually some sort of monitoring going on rather than a simple mileage-based indicator? Or is there some sort of vehicle use tracking/algorithm for determining oil life expectancy based upon severity of use (dusty, humid, short-trip, etc.)?
RandyH2 is offline   Reply With Quote
Old 01-20-2012, 08:28 AM   #16
peterk9
Ottawa, Ontario area
peterk9's Avatar
2014 Lincoln MKT AWD
Vehicle Specs
Quoted: 2210 Post(s)
I believe that it monitors the type of driving you do to determine oil life. I do more short trips than highway type driving and according to another thread I saw on this, my oil life percentage per mileage driven was lower than what others were reporting.
In any case, I continue to change the oil as I always have with my past few vehicles. Every 6 months or 5000 miles, which ever comes first.
__________________
Peter 2014 Lincoln MKT, 201A, 3.5L Ecoboost.
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds & 2011 AWD Explorer Ltd.
peterk9 is online now   Reply With Quote
Old 01-20-2012, 09:53 AM   #17
kert0307
Pella, Iowa
'00 Sport and '89 B2
Vehicle Specs
Quoted: 0 Post(s)
I'm pretty sure it's some algorithm based on type of driving. I find it odd on my wife's edge that you have the option of resetting the oil life to increments of 5 on a percentage of life like 100, 95, 90, ect
__________________
____________________
89' B2 -Sold
00' Explorer Sport - Sold
05' F250 Crew Cab 4x4 Diesel Clicky tow rig/DD
2011 Ford Edge - Wife's DD
1978 Glastron CVX16 Project Boat
kert0307 is offline   Reply With Quote
Old 01-20-2012, 02:00 PM   #18
FordService
Official Ford Rep
Dearborn, MI
FordService's Avatar
2014
Vehicle Specs
Quoted: 307 Post(s)
Does it just monitor your driving or is there an actual oil sensor?...
Quote:
Yes. Reset with the controls on the left side LCD screen. You should select something less than 100% when you do the reset since you have driven about 1,000 miles already. I suggest 90%...
Hey everybody,
Thanks for explaining how to reset the oil life monitor. This is just another example of why this community is awesome.
Quote:
The oil life monitor is based off the conditions the engine is driven under. Load, temperature, run time, etc... These all change how the oil breaks down. It all depends on the driving habits.
Cory
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordService is offline   Reply With Quote
Old 01-20-2012, 04:35 PM   #19
Fredridge
Los Angeles, CA
2011 Explorer
Vehicle Specs
Quoted: 3 Post(s)
thanks, I figured they forgot to reset it, used to happen all the time in my Silverado, but no adjustments - had to just turn the key on and off and floor the gas pedal several times and it reset.
Old 07-07-2012, 06:05 PM   #20
justjim_pia
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Originally Posted by FordCustSrvc View Post
Hey everybody,
Cory
Cory - is there a way to tell how many miles are left before the "change oil soon" message appears? I get a little paranoid waiting on the message to appear and it would be great to see the oil life count down on occation.
Best Regards,
Jim
justjim_pia is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil Coolers 2000StreetRod Modified 1995-2001 Explorers 89 12-13-2014 12:02 PM
Reset oil percentage deal...? Randys1 Stock 2011 - 2017 Ford Explorer Discussion 13 10-04-2011 01:23 PM
Oil Temperature Gauge install - an alternative temperature source Bronco638 Modified 1995-2001 Explorers 15 08-03-2009 11:52 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
