EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Why would "THEFT" light stay on?
Reply
Thread Tools
Old 04-10-2012, 05:10 PM   #1
Phili602
Phoenix
96 Sport
Vehicle Specs
(Original Poster)
I have a 1998 XLT Explorer and whenever I press the lock button on either the remote or the door to lock the doors, the THEFT light stays on and flashes brighter and its causing my battery to drain. Any suggestions are greatly appreciated!
Phili602 is offline   Reply With Quote
Old 04-10-2012, 05:17 PM   #2
NHarris
Ogden, UT
1998 XLT V6
Vehicle Specs
Quote:
Based off of my assumption (on my 98), all second gens have the theft light that flashes.
Let's specify here...
Is it causing your battery to completely lose charge, or just drain it slightly?
__________________
Nate H
1998 Ford Explorer XLT 4.SLOW Restoration Project - OEM Restoration with larger than stock tires.
2004 Jeep Grand Cherokee Laredo - 3.5" Lift, Quick Disconnects, Rear Locker, Mopar Off Road Package, Gray Moab Wheels, Differential Skid Plates, and much more!
NHarris is offline   Reply With Quote
Old 04-10-2012, 05:57 PM   #3
Phili602
Phoenix
96 Sport
Vehicle Specs
(Original Poster)
Well my battery was fine until i came out after leaving it sitting for a few days and it didnt want to start.... The theft light flashes on and off even when the doors are unlocked, but when i press the door lock button on either the door or remote, the theft light stays illuminated and just flashes brighter even though its already lit
Old 04-10-2012, 06:13 PM   #4
NHarris
Ogden, UT
1998 XLT V6
Vehicle Specs
Did you get your battery tested?
The ECU, radio, and whatever other electronics also are using power to stay on. I'll have to take a look at my X and see what its theft light is doin.
__________________
Nate H
Old 04-10-2012, 09:14 PM   #5
Phili602
Phoenix
96 Sport
Vehicle Specs
(Original Poster)
Yes i got my battery tested. 1st time was at a oreilly and they said it was no good. But I think the oreilly i went to is shady because I took the same battery to autozone and they said its good and fully charged it for me. 1 of the cells on the battery were low so I just added some distilled water and it seems to be keeping its charge but havent put it back in the x because I dont want it to drain it again. My previous x had the theft light and it would flash all the time weather the doors were locked or not. and it wouldnt stay lit and flash like this 1 is doing.
Old 04-13-2012, 03:41 PM   #6
Phili602
Phoenix
96 Sport
Vehicle Specs
(Original Poster)
Any suggestions on what could be causing the theft light to stay on at all times? How could i disconnect that light so it doesnt drain my battery?
Old 04-13-2012, 04:10 PM   #7
Trolling
kah-lee-fur-nyah
1997
Vehicle Specs
for the past few occasions that [I] had my instrument cluster all apart, my theft light bulb has been a tiny red LED. Even with that left on for a week, it can't drain a car battery dry.
Maybe there is something else draining your battery?
__________________
302 V8, BW4406, K&N CAI, 1" Phenolic spacer, TMH, Henson Custom Tune and a ticking noise problem.
Trolling is offline   Reply With Quote
Old 04-13-2012, 05:26 PM   #8
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
If it's blinking super fast and you hear a relay clicking at the same rate, then this usually means that the battery voltage is too low. If the battery is ~3-ish years old, then it's probably time to replace it. Another culprit could be of course the alternator not charging the batt.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 04-13-2012, 07:44 PM   #9
Phili602
Phoenix
96 Sport
Vehicle Specs
(Original Poster)
It may be another issue then besides the light
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED conversion: High Mount Brake light trucku Performance Lighting 18 06-15-2012 11:11 PM
My under the hood light install with pictures! XLT Modified 1995-2001 Explorers 15 04-18-2010 08:23 AM
Ranger dome light and cargo light stay on? nfazer Ford Ranger - Mazda B-Series Forum 2 04-12-2010 01:03 PM
How-To: Repair Broken 3rd Brake Light Socket (1st Gen) TedJ Stock 1991 - 1994 Explorers 0 08-31-2009 09:49 PM
Neon Light Write-up Glowin97x Performance Lighting 26 03-04-2009 07:15 AM
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
