Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Auto Hubs & Front Axle
Reply
Thread Tools
Old 02-09-2004, 07:28 PM   #1
flyboyerau
Prescott, Arizona
'94 XLT
Vehicle Specs
(Original Poster)
Well, now that winter is here again, my 4X4 is out again. Murphy's law is also at work again The 4 wheel drive doesn't work. When I push the switch on the dash, the trnsfer case engages fine. I put the Ex on jackstands to make sure power is going to the front axle. Here is the first problem. The driver's side axle turns fine, but the passenger side will not turn at all. I am wondering if this is a u-joint problem or something more severe. Also, both hubs will not engage. I have pulled them both apart only to find them loaded up with grease. I cleaned the grease off and tried it again, still not engaging. I will try the solvent followed by the ATF in the cast aluminum part, and will clean the other components with solvent as well. One thing that was missing from the assembly was the 2 thrust spacers behind the cam assembly on both sides. I would like to know if ANYONE has a component/rebuild kit other than Ford. I would also like to know if anyone has any ideas about the front axle. Thank you all for your help
flyboyerau is offline   Reply With Quote
Old 02-12-2004, 02:18 PM   #2
bates
Shine on Benevolent Sun
Kingston, Ontario, Canada
bates's Avatar
1991 Eddie Bauer 4x4 4dr
Vehicle Specs
I could be wrong, but I would say this is due to a lack of a front locker.
__________________
Josh Johnston
2006 Toyota Yaris RS <-- beater
1991 Explorer 4dr 4x4 EB
1989 Mustang LX 5.0L
bates is offline   Reply With Quote
Old 02-12-2004, 02:46 PM   #3
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
It sounds like it is working ok. If both hubs are locked with an open differential all power will go to the wheel with least resistance (driver' side). The passenger side front axle is longer and contains an additional U-joint making it have greated resistance than the driver's side.
That being said if the driver's side HUB was locked and the passenger side unlocked then the passenger side would then have the least restistance. The driver's side now as the additional resistance of the entire wheel. The passenger axle would spin, but NOT rotate the tire.
So to confirm you could prevent the dirver's side wheel from moving and power will be transfered to the other side.
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 02-12-2004, 03:09 PM   #4
flyboyerau
Prescott, Arizona
'94 XLT
Vehicle Specs
(Original Poster)
Ok, thats a big help and i was doubting the broken u-joint anyway. The new problem is that I can lock the passenger side hub by hand by turning the u-joint manually so I know the passenger side works. The drivers side still does not work though. I need to pull it apart and get all of the grease out of it, and then try it again. I noticed that when I re-assembled the pasenger side hub, it was springy when I pushed the aluminum hub onto the rest of the assembly. That was not the case on the driver's side. The hub wasn't springy at all. Could that be a sign that the spring is packed full of grease. Anyone know whats going on now?? Thanks!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
