Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
Lowbeam out Highbeam works
Reply
Thread Tools
Old 02-14-2004, 06:18 PM   #1
khissam
waxhaw, nc
95 Eddie Bauer
Vehicle Specs
(Original Poster)
95 Eddie right lowbeam does not work , but the high beam does. I replaced the bulb it did not fix it. Tried Fuse,cleaned contacts on connector no go.
Hs anyone seen this before and what did it take to fix.
Thanks in advance
khissam is offline   Reply With Quote
Old 02-14-2004, 06:37 PM   #2
xploder97
Schaumburg, IL
'97 V8 AWD XLT
Vehicle Specs
I would try and see if its the Multi Function Switch on the steering column, on ocasion they will burn out and the only way to have light is to hold the Flash to pass switch to have lights if thats the case i would replace it...Very easy to do with simple screwdrivers.
xploder97 is offline   Reply With Quote
Old 02-14-2004, 06:45 PM   #3
khissam
waxhaw, nc
95 Eddie Bauer
Vehicle Specs
(Original Poster)
Tried it no go.
Old 02-14-2004, 09:50 PM   #4
Harry5150
Santa Clarita, CA
Harry5150's Avatar
05 Dodge Durango Limited
Vehicle Specs
Try wiggling the wires that go into the harness of the multifunction switch/ stalk. I ended up replacing mine and it fixed it.
__________________
Borla Catback / K&N FIPK / 6" S-TT Lift
My Truck | My Mug
Spindle Lift Install: How To | Ball Joint & Tie Rod R&R: How To
Harry5150 is offline   Reply With Quote
Old 02-14-2004, 10:25 PM   #5
dogfriend
Human-Animal Hybrid
Carmichael, CA
dogfriend's Avatar
'97 Sport 4x4
Vehicle Specs
Check out this thread.
LOWM
I have seen other people have problems with this module causing headlight issues.
Also, this might help: Where is the LOWM?
dogfriend is offline   Reply With Quote
Old 02-15-2004, 12:13 PM   #6
gonzo_128
LaPorte, TX
'97 xlt
Vehicle Specs
i had this same problem. all the fuses were good, etc. it turned out to be a burnt or bad relay. (in the distrbution box under the hood.) you really can't tell by just looking at it.
gonzo_128 is offline   Reply With Quote
Old 02-15-2004, 03:11 PM   #7
darknite3603
Latrobe, PA
97 XLT
Vehicle Specs
I also had the same problem, it was my multi switch on the steering col. I had to take it to a ford shop to figure it out though. You might want to take it to a garage and have them run a diag on it. But do it soon because if it is doing the same thing mine did it was starting to melt the wiring harness.
darknite3603 is offline   Reply With Quote
Old 02-15-2004, 03:37 PM   #8
khissam
waxhaw, nc
95 Eddie Bauer
Vehicle Specs
(Original Poster)
Check LOWM did not see any burned out Transistors. I see that some people responded that it may be the Multi Function Switch in the steering column.
Is this something I can replace on my own? and get the part at a local parts shop?
Ken
Old 02-15-2004, 07:41 PM   #9
Harry5150
Santa Clarita, CA
Harry5150's Avatar
Vehicle Specs
It's a do it yourself job.
4 screws to get the plastic covers off of the column and 2 (torx) to get the switch off.
Unscrew the tilt wheel lever.
3 harness plugs to deal with.
__________________
My Truck | My Mug
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
