Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Street Truck & Performance Forums > Street Trucks
Notices
Street Trucks Do you have an Explorer Street Truck? Something setup for the road with handling more of a priority than ground clearance? This is the forum for you.
Mountaineer AWD Disable?
Reply
Thread Tools
Old 02-19-2004, 05:30 PM   #1
shelby69
Allentown, PA
97 Cobra, 97 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 5.0 AWD Mountaineer. Can I disable the AWD? I assume it is different than Control-Trac. If anyone has any info it is greatly appreciated.
I searched but didn't find anything about Mountaineer.
Thanks
shelby69 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-19-2004, 05:38 PM   #2
IAmTodd
4x Explorer Veteran
Johnstown, PA
IAmTodd's Avatar
2001 Jeep Cherokee
Vehicle Specs
Quoted: 20 Post(s)
No, the AWD Transfer Case is a permanently engaged. There is no electrical connections that can be "clipped" to fool the computer. I'm not sure if the you can just remove the front drive shaft or not. But the best way is to remove the T/C and replace it with the 2WD driveshaft and taleshaft.
__________________
2015 VW Jetta SEL TDI 6MT
2001 Jeep Cherokee Rubicon Express 4.5 lift
IAmTodd is offline   Reply With Quote
Old 02-19-2004, 05:41 PM   #3
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 22 Post(s)
You can remove the front shaft and run it that way. I am not sure what the long term wear would be like though. Heath has been running that way for at least a few months now.
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 02-19-2004, 05:48 PM   #4
shelby69
Allentown, PA
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How does the transfer case know to transfer power front or rear? It doen't use the wheel speed sensors? Is it all viscus couplings? I work for an Audi dealer so I understand Quattro, but I am unfamilar with the Ford AWD.
Old 02-19-2004, 05:54 PM   #5
IAmTodd
4x Explorer Veteran
Johnstown, PA
IAmTodd's Avatar
2001 Jeep Cherokee
Vehicle Specs
Quoted: 20 Post(s)
From my understanding its all mechanical that uses a viscous copuling.
__________________
Old 02-19-2004, 05:59 PM   #6
IAmTodd
4x Explorer Veteran
Johnstown, PA
IAmTodd's Avatar
2001 Jeep Cherokee
Vehicle Specs
Quoted: 20 Post(s)
Quote:
Originally posted by Ak LTD Xplorer
it's allway's sending power to the front..all the time..nomatter what..35% to the front 65% to the rear FULL TIME
Varies front to back too. Not always the same tourque split.
__________________
Old 02-19-2004, 06:15 PM   #7
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 22 Post(s)
Up to 95% to either axle.
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 02-19-2004, 06:19 PM   #8
IAmTodd
4x Explorer Veteran
Johnstown, PA
IAmTodd's Avatar
2001 Jeep Cherokee
Vehicle Specs
Quoted: 20 Post(s)
Does it use a regular open diff in the front, or is that a LS? Or is it just basically a regular 4WD drive train with an AWD T/C(sounds kinda confusing, i know )
__________________
Old 02-19-2004, 07:09 PM   #9
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
Quoted: 0 Post(s)
The front or rear axles are sent more power if the system senses the wheels slipping. An AWD system would be worthless if it stayed at the same torque split 100% of the time.
__________________
1996 Explorer 5.0 V8 - TT/shackles, 31" BFG A/T - Registry thread
2005 Mustang GT - Sonic Blue
Hartman is offline   Reply With Quote
Old 02-19-2004, 07:16 PM   #10
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
Quoted: 0 Post(s)
I don't think it's all mechanical.
__________________
Old 02-19-2004, 07:19 PM   #11
Robb
Vehicle Specs
Quoted: 0 Post(s)
It doesn't take a computer to "sense" slipping.
Robb is offline   Reply With Quote
Old 02-19-2004, 07:28 PM   #12
Robb
Vehicle Specs
Quoted: 0 Post(s)
Ever heard of limited slip differentials? They work, basically, in the same way. Mechanically, it senses when a wheel is slipping, and applies power to the other side. The AWD tcase does the same thing, just to the driveshafts.
You can read about limited slips at www.howstuffworks.com . Search for "differential".
btw: I can figure out for myself when questions are hard or not.
Old 02-19-2004, 07:32 PM   #13
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
Quoted: 0 Post(s)
__________________
Old 02-19-2004, 08:00 PM   #14
Billy177
Redding CT
99 Explorer XLT SOHC 4x4
Vehicle Specs
Quoted: 0 Post(s)
maby i am wrong but i thought limited slip has a cutch plate inside that sends power to both weels also allowing one wheel to spin when the clutch is overpowered.
for all wheel drive i think the rear driveshaft is perminatly connected to the tranny and the front through the viscous coupling
__________________
1999 4.0 Sohc XLT 4x4 3.55 31' BFG MT
Mac Air Intake, High-Flow cats, Excalibrator
Flowmaster 50 Series Cat-back,Rancho 5000's,
TT + Shackles, 200 Amp Alternator,
Autometer Gauges, 150 Watt Lights
Detroit Locker in Rear
Billy177 is offline   Reply With Quote
Old 02-19-2004, 09:32 PM   #15
boominXplorer
Elite Ranger
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
Quoted: 192 Post(s)
Quote:
Well does he loose alot of power to the front?
__________________
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0 swap, FMS headers, 4406, 4.88s, 5" lift with Coilovers, 3" body running 315/75/16 MTZs
2007 Ford Focus ST Black - FS Intake, SVT brakes F&R, Fiesta ST 17s
My eBay auctions
boominXplorer is offline   Reply With Quote
Old 02-19-2004, 09:46 PM   #16
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
Quoted: 0 Post(s)
If you have a 2WD option in the 4x4 system like my truck does, then you can leave it in that mode and remove the the whole front drivetrain and be fine, or so I've heard. When I swap in 2WD spindles, I plan on removing the CVs and front driveshaft. Eventually, I will dig out the axle. I'm gonna leave the t-case there too.
__________________
Old 02-19-2004, 09:51 PM   #17
Billy177
Redding CT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
if you remove the front driveshaft you loose all power to the front and 100% is sent to the rear
__________________
Old 02-19-2004, 10:57 PM   #18
John_Rock
Elite In Memoriam
Houston, TX
John_Rock's Avatar
2001 Sexy Sport Trac 4x4
Vehicle Specs
Quoted: 0 Post(s)
Since none of us work for Borg Warner and don't really know how the inside of the AWD transfercase really works, then let's stop guessing.
Things I know for sure about it:
1. It is an all mechanical transfercase. Absolutely no wires connecting to it.
2. You can still drive it with the front driveshaft removed.
3. If you do have the front driveshaft removed, use the parking brake everytime you park. If the truck is on an incline it will creep down the hill otherwise.
4. You can tow with the front driveshaft removed.
This last weekend I towed 6000+lbs with the front driveshaft removed.
__________________
John_Rock - Mugshot - Click Here For info on my 2001 Sport Trac 4x4
- 2000 Explorer Limited AWD, 5.0L v8; 4.10 gears, KKM True Rev filter, B&M Tranny Super Cooler, Aux. Tranny Filter, Autometer Tranny & Water temp gauges.
Demon4x4.com
John_Rock is offline   Reply With Quote
Old 02-19-2004, 11:01 PM   #19
section525
sextion525
Red Bluff, Ca
section525's Avatar
Vehicle Specs
Quoted: 22 Post(s)
Duude.. did you notice anything weird going on? How was the power difference? Did you light up the wife's tires?
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
Old 02-19-2004, 11:08 PM   #20
Jefe
Clarksville, TN
'00 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Quote:
You're one crazy guy
After a bit of Googleing:
Rebuild pics of a BW 4404 (AWD) case
__________________
'00 Explorer XLT - Sold
'01 Focus SE
Jefe is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
