Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Advice on Trimming
Reply
Thread Tools
Old 03-24-2004, 09:09 AM   #1
bhults
Forked River, NJ
bhults's Avatar
1995 Eddie Bauer
Vehicle Specs
(Original Poster)
Advice on Trimming
I've heard an awful lot about trimming, and I'm now at that stage in the game where I'm gonna have to do some. I've completed a TT/Shackle/Double AAL lift and I just ordered 32's on 15 inch rims. I test fit these tires courtesy of Matt (Sk1er17), and found that I'm gonna experience a little rubbing, but not enough to downgrade to 31's Sooooo, I'm seeking advice on how to trim. I've got an Eddie, so I've got those running boards...which I like, but they're a rubbing point. Should I trim them down, or rip em off and get nerfs? How do you go about trimming the inside wheel well? Is there anything I gotta look out for? Nothin' like putting a Sawzall thru something you didn't mean too I'm just looking for some honest opinions and experiences on what works best when trimming, how to do it, and how NOT to hack up your truck when doing it. Also, the nerf bar/running board dilemma...anyone swap out one for the other? Any and all suggestions welcome! Man, I'm excited! (got a great deal on those ProComps, too! )
__________________
Ch Check it Out
bhults is offline   Reply With Quote
Old 03-24-2004, 09:16 AM   #2
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
Well if you removed the running boards i think the bottom of the fender flares would look awkward and removing the fender flares usually reveals holes in the fenders... so i'd suggest you only trim on the inside of them if possible, also a sawzall my be kind of tricky and dangerous to swinging around in there, try just using a sheet-rock hole saw and utility knife first, thats all I needed except for the little bit I took off the pinch weld. the front bumper was pretty easy for me because mine was all plastic but yours might be more difficult noticing that its metal. Good Luck!
Nick26 is offline   Reply With Quote
Old 03-24-2004, 09:19 AM   #3
GJarrett
Moderator Emeritus
Chief GPS'um and Still Lost Native Texan
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
The inside of the front of the running board can be completely trimmed out for clearance and if you do it carefully no one will even be able to tell that you did it. It is plastic - use a utility knife, it's a ten minute job.
__________________
Ol' Krusty
"Nerves of Steel; Brain of Chipmunk"
Gerald's Truck
The best things in life........ aren't things.
God's aim looks like He's missing the mark because we're too nearsighted to see what He is aiming at.
GJarrett is offline   Reply With Quote
Old 03-24-2004, 09:25 AM   #4
bhults
Forked River, NJ
bhults's Avatar
1995 Eddie Bauer
Vehicle Specs
(Original Poster)
Yes, Gerald, I was reading the big long post you made regarding all sorts of stuff. I know you've got the Eddie too (and LIKE the running boards as do I) and trimmed the inside to make your shoes fit. I didn't quite understand how you trimmed though, but I'm glad to hear that it came out looking good. Did you trim right along that inside part (of the running board) where it kind of "bells out" before curving in toward the vehicle? I see that as being a major rubbing point. How about the front bumper. The whole bottom half is plastic, and I don't think I'm going to have to trim any metal. Thanks!
Bill
__________________
Ch Check it Out
Old 03-24-2004, 09:40 AM   #5
GJarrett
Moderator Emeritus
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
Yep, you got it exactly, you can remove almost all of that big "bellbottom" leaving just a 1/2" or so lip instead of that huge bell. Do it right and carefully follow the contour of the front of the board and it will look factory, like Ford could have designed it without the bell in the first place. To fit 33's, I did have to also trim out an inch of the bottom plastic at the rear of the front bumper to clear the front of the tire - I don't know if you will need to do that for 32's or not. A utility knife will not cut the plastic on the bumper; you'll need a jigsaw or SawZall and then file the cut smooth. You will probably also find that you will have less clearance for your right tire than left - our vehicles are not perfectly symmetrical and the left tire will have more clearance than the right.
__________________
Ol' Krusty
Gerald's Truck
Old 03-24-2004, 09:41 AM   #6
jasonb
Jackstand Wheeler
Suwanee, GA
jasonb's Avatar
'99 Sport 4x4
Vehicle Specs
a dremel tool with a cut off wheel works amazing for cutting that plastic also.
the front bumper is easy to trim and is all plastic. the rear of wheelwells, all you should have to trim is the part of the tan plastic that wraps around inside the wheelwell.
i wouldn't think you have to trim much at all though. and yeah my passenger side is hacked up a LOT more than the driver side.
__________________
JasonB
--Thanks to all the great people in the military for keeping us safe.--
jasonb is offline   Reply With Quote
Old 03-24-2004, 09:44 AM   #7
GJarrett
Moderator Emeritus
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
Oops.... yeah, forgot about a cutoff wheel..... It will cut through the bumper plastic like butter.
__________________
Ol' Krusty
Gerald's Truck
Old 03-24-2004, 10:22 AM   #8
bhults
Forked River, NJ
bhults's Avatar
1995 Eddie Bauer
Vehicle Specs
(Original Poster)
Great!
This all sounds really great....I plan to get the tires first, put them on and see exactly where the trimming will need to be done. I'd like it to look as 'natural' as possible. I don't have a dremel, but maybe I'll just go pick one up. I think I've spent more money on tools for this project than I have on parts (save the rim/tire package :p ), but if it makes the job easier, I figure I need it!
__________________
Ch Check it Out
Old 03-24-2004, 10:26 AM   #9
bhults
Forked River, NJ
bhults's Avatar
1995 Eddie Bauer
Vehicle Specs
(Original Poster)
Oh, and....
....what about that pesky pinch weld? The pinch weld is that little piece of ominous looking metal that looks as if it could destroy your tire if given the chance, right? What tool can be used to cut that? Or, can I just bang it in with a hammer to get it out of the way?
__________________
Ch Check it Out
Old 03-24-2004, 10:31 AM   #10
Jefe
Roll Over Posse Recruiter
Clarksville, TN
'00 XLT 4x4
Vehicle Specs
Re: Oh, and....
Quote:
If you need to move/remove the pinch weld (I didn't till I had 35's) a good sized hammer will smash it flat
__________________
'00 Explorer XLT - Sold
'01 Focus SE
Jefe is offline   Reply With Quote
Old 03-24-2004, 10:53 AM   #11
bhults
Forked River, NJ
bhults's Avatar
1995 Eddie Bauer
Vehicle Specs
(Original Poster)
Sexcellent!
Nothing like just smashing something outta the way. Somehow, it gives you more gratification by doing it like this!
__________________
Ch Check it Out
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
