| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum |
Thread Tools |
#1 |
Wannabe Elite Explorer
Toronto. Canada
1998 xlt
cleaned intake, MAF,IAC and then oil change...now CEL is on?
Hi there, i'm off tomorrow to the biggest wheeling trip i've organized and so today i decideded i'd try to do a mini tune up. I did the drip down intake clean thing, used electrical cleaner on the MAF and IAC and changed the oil (and spilt it all over everything!).
I was a quart short, so later on this after noon, after about driving 25km, i bought some oil and added it. Now my check engine light is on, it's not even comming off when i disconect the battery ???? Any idea's? I know it's hard to say, but maybe someone has run into this before? I do smell a slight burning scent that was around when i was doing the intake clean, and i had cranked the engine over once without oil, to get the oil from the pump... __________________ 98' XLT SOCH 4X4, locked in rear, " suspension life, 3" BL, 33 X 12.5 Truxus At's, Classic II wheels, tow hooks, Magnaflow and intake, Rancho RSX's, CB... |
#2 |
Long Island, NY
97 Mountaineer
If you did an intake cleaning you might have gotten some fluid into the cylinders causing a slight misfire. If you pull the code it will probably be a p0300 radom cylinder misfire.
#3 |
C.A
91 zuki
when u disconected the battery did u leave it sit for 20-25 mins? i belive it takes a bit of time to reset the computer
| Thread Tools | |
