#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
How to: Clutch Switch Bypass
Reply
Thread Tools
Old 05-08-2004, 05:19 PM   #1
hvac man
Rifle, CO
hvac man's Avatar
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys whats up? I was searching for a good thread on how to bypass the clutch safety switch and was soon dissapointed that there was not much help. I then went out to the garage and started messing around with the wires and found an extreamly easy way to bypass the switch.
What you will need:
screw driver
wire strippers
Wire connectors
18ga wire
on/off type switch
Step 1:
Locate the sensor on the clutch pedal and remove.
Step 2:
Locate pink, and red/blue wires.
Step 3:
Splice the two of them together using a crimp-on wire splice connector.
Step 4:
Reinstall the sensor to the clutch pedal and your done.
There is another way to do it using a 2 position switch so that when the vehicle in not off-road the switch will work like normal. For this method follow these steps.
Step 2 A:
use a crimp-on wire connector on each of the wires indevidualy with a pig tail wire off of each one.
Step 2 B:
Run each of the pig tail wires into a standard two position toggle switch.
Step 2 C:
Refer back to step 3 to finish.
Pictures to follow in the next post.
__________________
'94 XLT 4 door- let the adventure begin!
93 Explorer 2-door with some mods R.I.P.
'96 Toyota 4runner SR5
hvac man is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-08-2004, 05:33 PM   #2
hvac man
Rifle, CO
hvac man's Avatar
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The pics and what you will need:
__________________
Old 05-09-2004, 05:18 PM   #3
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL Pumpkin Edition
Vehicle Specs
Quoted: 399 Post(s)
Finally!! I was hoping someone would figure that out Thanks!
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
1960 Dodge Dart Seneca
Rick is offline   Reply With Quote
Old 05-09-2004, 08:03 PM   #4
hvac man
Rifle, CO
hvac man's Avatar
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I saw that you guys had posted a thread about working on it but no one had ever replied about finishing it That was like a year or more ago so..... I hope it helps someone.
__________________
Old 05-10-2004, 12:13 PM   #5
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
Hey HVAC,
If you go look at an automatic equipped truck Ford installed a bypass clip in the clutch 3 position harness. Simple, just a little jumper for the 3-4 circuits...
When I converted my truck from stick to auto I used the ford clip to elimiinate the clutch 3 pos switch, just like Ford would do. Same computer harness for a 5 speed or auto, manual or auto t case, etc.. only changes are in the transmission harness.
All the 3 pos switch does is tell the following when the clutch is in:
Cruise control
4x4 Electric shift
Neautral safety
What did you need to tap into it for? Your new T case?
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 05-10-2004, 08:56 PM   #6
hvac man
Rifle, CO
hvac man's Avatar
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I just did it because I think that anyone serious about wheeling in a 5 spd should think of this as a prerequisite. I for one do not like pressing the clutch in on a steep hill or what not
I also did this mod for .10 cents and I never had to leave my garage I think that is worthy of sharing it with the rest of the members here
__________________
Old 05-11-2004, 03:51 PM   #7
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
You mean to start the truck back up after a stall?
Which one did you bypass?
__________________
Old 05-12-2004, 12:51 AM   #8
hvac man
Rifle, CO
hvac man's Avatar
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Yes, I bypassed the safety switch
__________________
Old 05-12-2004, 11:36 AM   #9
rpenner54
Moderator Emeritus
Wichita KS
rpenner54's Avatar
06 2500 Duramax
Vehicle Specs
Quoted: 0 Post(s)
Man I did this years ago... Except I never "re-wired" it I just moved the switch and the saftey down on the clutch pedel. The only issue I had was the truck wasn't geared low enough to start up in gear...
Those with an atlas probably won't have that problem.
Make sure your battery cables are CLEAN when doing this.
__________________
Ryan
14 Ford Focus
93 Isuzu Trooper
rpenner54 is offline   Reply With Quote
Old 06-03-2004, 04:54 PM   #10
Crankcase
Moderator Emeritus
Vancouver B.C, Canada
Crankcase's Avatar
1992 XL Ex-Police
Vehicle Specs
Quoted: 0 Post(s)
CAN
So in theory...One could use that as a Ignition disabler on an auto if they put a switch in the line .....hrm.
__________________
*Explorer Family*
1992 XL Mine 1992 XL Sisters
1992 XL Dads 1994 XL Moms
Ex-Moderator: Modified Explorations Drivelines
New Member Forum
***Guest star poster....
Crankcase is offline   Reply With Quote
Old 06-03-2004, 06:16 PM   #11
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
Crankcase, that is correct.
If you look under your dash you will see ther wiring for the 3 position clutch switch is there, Ford just installed a plastic clip that effectiveley jumps the 3 circuits, one of them is the ignition feed (clutch must be pushed in to start truck)
Of course the same wire can be found in the steering column, and transmission harness (neautral safety).
So all you gotta do is put a switch on it and waalaa! kill switch to disable the starter.
Excatly what they do when they install an alarm, they cut the wire and route/loop it to a relay controlled by the alarm....
__________________
Old 04-25-2005, 07:26 PM   #12
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
Vehicle Specs
Quoted: 399 Post(s)
I finally did this mod. It works great with the Atlas II. No problem at all starting in gear while in low range
__________________
2004 Mustang Mach 1
Old 09-25-2005, 05:17 PM   #13
FireZapper
Columbia Pa.
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
The info in this post was worth the elite status.
Thanks, I installed a switch inline of mine.
__________________
My Elite
93 Sport FW HP Dana 44 and 8.8, Stubbler, WH 5.5 springs, warrior shackles, 36 TSL/37 Boggers, 513's, Spooled front and Welded rear, BBP cage, bumper and sliders.
My 3/4 door project.
FireZapper is offline   Reply With Quote
Old 09-26-2005, 09:22 PM   #14
Crankcase
Moderator Emeritus
Crankcase's Avatar
1992 XL Ex-Police
Vehicle Specs
Quoted: 0 Post(s)
CAN
Another satisfied customer
__________________
*Explorer Family*
New Member Forum
Old 03-27-2007, 12:57 PM   #15
little x
SW VA
'91 XL
Vehicle Specs
Quoted: 0 Post(s)
I just did this mod. Thanks for posting the info (years ago, haha)! It took me longer to drive 5 miles to the store and back then it did to do this mod.
I did mine a little differently. I cut both wires right next to the clutch and put covers over those ends. Then hooked the free ends up to a switch.
One switch position and the clutch safty is bypassed, the other position is an anti-theft setting and the starter won't turn.
little x is offline   Reply With Quote
Old 11-25-2008, 04:14 PM   #16
Damonkr
Cottage Grove, OR
2002 Ranger fx4 7"&35's
Vehicle Specs
Quoted: 0 Post(s)
Anyone tried this mod on a newer model. I am trying to do this currently on my 02.
Damonkr is offline   Reply With Quote
Old 11-25-2008, 05:34 PM   #17
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
Quote:
The clutch/starter interlock is similar on your 02 Ranger. The color codes at the clutch switch connector should be solid pink and white w/pink stripe.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
Ford owners' manuals ONLINE, then click on "Glovebox"
rwenzing is offline   Reply With Quote
Old 11-25-2008, 06:16 PM   #18
Damonkr
Cottage Grove, OR
Vehicle Specs
Quoted: 0 Post(s)
Ill try those. I blew a fuse with the other colors thanks.
Old 11-25-2008, 06:26 PM   #19
Damonkr
Cottage Grove, OR
Vehicle Specs
Quoted: 0 Post(s)
Update for newer models
Went out and tried those wires (solid pink, white w/pink stripe)and worked perfect.
Those are the wires in the 1 and 2 positions on the plug.
Old 11-25-2008, 09:43 PM   #20
rwenzing
Michigan
Vehicle Specs
Quoted: 2 Post(s)
__________________
Bob
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Comprehensive Brown Wire Mod Thread gijoecam Explorer & Ranger Transmissions, Transfer Cases, & Differentials 385 01-25-2016 11:16 PM
03 explorer remote starter problem-poss bypass switch harleeflstn Stock 2002 - 2005 Explorers 3 02-06-2011 04:12 PM
Clutch pushrod & bypassing the interlock switch. HappyBuddaH Stock 1991 - 1994 Explorers 4 01-05-2009 10:21 AM
Clutch Interlock Switch Mod - Question HappyBuddaH Under the Hood 1 12-07-2008 12:42 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
