V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
Intermittant Missing Problem/Slugishness
I've had a missing/lack of power/CEL problem for a little bit, recently its become much more troublesome.
Truck
Base: 1997 Mercury Mountaineer 5.0 302 V8. 4R70W Automatic.
Mods: see link below for Elite Registry
Symptoms Summary:
- The computer will routinely generate codes P0300 - Random Misfire and P0340 - Camshaft Position Sensor Failure.
-The truck feels sluggish, like its towing a heavy trailer (i looked... its not) or the breaks are dragging (they're not), or its not running on all cylinders.
-The truck smells like its running very rich. When I back up, It smells like latex paint or turpentine. I've been filling up at several different gas stations, all high volume and no difference in smell. The truck has been averaging about 10 miles per gallon in mixed driving, it used to get around 13.
- There is often a surging or bucking. Sometimes it is minor, other times VERY pronounced. This is usually when the CEL is set off.
-The last two times I filled up with fuel from the same high volume Sunoco station, about 15min/3miles later the CEL will be thrown and the truck will run like crap. It feels like its running on half its cylinders, won't idle, shakes, very slow, etc. There was a very strong smell of gas in the cab as well. I'm thinking canister purge system? Both days it was around 75 degrees out, and I was in stop/go traffic.
Parts Installed in effort to correct problem:
- I have installed a new Camshaft Position sensor, but the P0340 continues to be thrown.
- It has Bosch platinum plugs, and Autozone 8mm Silicon wires within the past 2000 miles.
- Fuel filter was replaced about 1.5years/14,000miles ago
- Seafoamed through brake booster hose last night
- MAC open air cleaner last summer
Tests Preformed so far:
-Vacuum: At hot idle it reads steady at 14.5-15psi. There is a small, gradual fluctuation of the needle that takes about 2 seconds to complete.
-Rail Fuel Pressure: At hot idle is steady at 36psi. Engine off it is 40psi.
-Connecting my OBD-2 scan tool (Alex Peper's computer interface), I have found some interesting results:
1) TPS: Set at the ideal 0.96 volts, the computer reads 18% Open. Set at .63volts, the computer reads 12% open. This is the lowest it will go without unplugging the sensor. If I disconnect it, the value does drop to 0.0%, and the CEL will be thrown.
2) Engine Load: The engine load percent value is around 35% for idle both in and out of gear. It goes to about 50% load by 1500rpm, and 90% load at 2500 rpm. Seems High. OBD-2 Calculated Engine Load is a funtion of airflow, barometric pressure, and stored values.
3) O2 sensor: Seems to be ok, fluctuating between 0.065 and 0.745volts on both banks.
4) Fuel Trims: While driving at 1600 rpm, engine load 54.5%, the short term is 1.6, and the long term is -7.8. On the drive, the long terms were as low as -11.17. The shorts were around 4.7
I'm not sure how to interpret all this data I now have availible to me with the scanner! I can report a lot more, as well as send the scan files to you showing the sensor values in "real-time" if that would help.
Truck
Symptoms Summary:
