Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Power Steering Fluid/Flush Question
Reply
Thread Tools
Old 07-01-2004, 12:27 PM   #1
Cali' Explorer
Sacramento, CA
'97 XLT 5.0
Vehicle Specs
(Original Poster)
Hey all, did some searching on this but haven't found a definitive answer yet.
I want to do a Power Steering Fluid Flush on my X. It has about 85K miles on it, and I was recently told by the local shop that I have do my oil changes that the fluid looked like it needed to be replaced (very dark, checked it out myself). I was just going to do a flush myself using the methods listed in my Haynes manual.
The problem I'm running into is deciding what Power Steering fluid I should run. My Haynes manual says to use regular Mercon ATF in the Power Steering pump. I was hoping to go to a full Synthetic fluid to hopefully increase the life and performance of the Power Steering Pump. What I'm trying to decide is should I just stick with the basic Mercon ATF, with regular "Power Steering Fluid", "Synthetic Power Steering Fluid" or Mercon V ATF (Synth)? I personally would prefer to run synthetic just because my experience with Synthetic has always been good, but I don't want to damage my X either (This X has to last me through another 3 years of school without any major repairs).
Also, anyone with a '97 5.0, or one with the White "See Through" Power Steering Fluid Reservoir, do you have a hard time seeing through the window to see the level? I have tried cleaning the outside and haven't come up with a solution to make it clear enough that I can see what the Power Steering fluid level is inside. I've been using a jury rigged metal bar with a high tech "stop" so I can accurately measure inside and then pull it out and measure against the line on the outside of the can, but I want to get it cleaned and use it like its meant to be.
Sorry for the long thread, thanks for any help you can give =).
__________________
Steven West
Sadly, I'm Explorer-less now....
Cali' Explorer is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
