Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Transfer case speed Sensor
Reply
Thread Tools
Old 07-10-2004, 07:21 PM   #1
Joe Fast
Brooklyn, New York
1999 XLT
Vehicle Specs
(Original Poster)
Question... Being that these things are just magnets.... Can they go bad? Has anyone had to change a speed sonsor on the transfer case without doing the shift motor? Reason being... I am about to swap in a new shift motor and keep the old sensors (which have been cleaned); however, there was some water seepage into the transfer case at one point (which has long been resovled with many frequent fluid flushes). The car is running great without the shift motor installed but I would like to have the option of 4WD again. Shoud I go out and buy brand new sensors and splice them in?
Any help would be appreciated.
Joe
Joe Fast is offline   Reply With Quote
Old 07-11-2004, 07:25 PM   #2
Joe Fast
Brooklyn, New York
1999 XLT
Vehicle Specs
(Original Poster)
hi
Old 07-11-2004, 07:28 PM   #3
Eric P
Las Vegas, Nevada
"98 Mazda B-4000 4X4
Vehicle Specs
The ones in my '92 still work, IMHO if it still works dont fix it.
__________________
Eric
'98 Mazda B-4000 4X4 120,000 miles 4.0 pushrod engine
Eric P is offline   Reply With Quote
Old 07-12-2004, 11:17 AM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
The speed sensor is available at most aut parts stores, Autozone carries them for about $18 I believe.
Did you spend $300 for a new shift motor? OUCH!!
You will have to swap the gear from the end of the speed sensor to the new one, however it is likely there is nothing wrong with your sensor...
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 07-12-2004, 02:55 PM   #5
easnoddy
Bogart, GA
1997 Sport 4WD
Vehicle Specs
Sweet, glad there's a thread about this. I have to replace mine because I have a fluid leak due to the O-Ring flattening completely. I have already bought a new one from Ford ($40 Ouch). Anyways, I need to pull the old one out.
My question is, how hard is it to get the wires out of and into the large black connector? I have pulled it apart but am nervous about pulling the leads out of it since the new leads may be tough to put in. Has anyone done this? How easily do the leads go in or out of the connector?
easnoddy is offline   Reply With Quote
Old 07-12-2004, 02:58 PM   #6
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
You will find with this connector, and in fact with all the Ford connectors on the truck, they come apart quite easily. You see there is a red piece of plastic in the middle of the plug that is responsible for holding all the pins inside in locked position.
With the right tools you can pry the keeper out, then it is just a matter of unlocking each pin and pulling them out.
Make sure you note the position of each wire
WHy do you need to pull it apart?
The speed sensor wires do not go throught he big black plug, do they?
__________________
Old 07-12-2004, 03:03 PM   #7
easnoddy
Bogart, GA
1997 Sport 4WD
Vehicle Specs
I pulled the connector apart and saw the keeper holding the pins. The 3 wires (blue, green, grey) from the sensor go through the plug (unfortunately). So how do I get this keeper thing out? I only have to remove/replace 3 wires, seems like a pain to have to do all the leads.
Old 07-12-2004, 03:06 PM   #8
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
keeper probably pries out, needlenose might grab it.
I have not taken this plug apart on my truck but I have looked at it enough to know the keeper is in there.
On many plugs there is a slot in the side of it that allows you to insert a smallscrewdriver under the keeper and pry it out.
With this big plug you are better off doing it the right way, removing the keeper, re-pinning the new leads, and putting them in the plug. cutting and soldering is the alternative, but with the amount of weather this plug see's I would go against solder and heat shrink because eventually it will corrode
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
