#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
5.0 V8 Ford Motorcraft platinum spark plugs REVIEW & FEEDBACK
Thread Tools
Old 07-13-2004, 11:44 PM   #1
Oversquare
Wine Country
'00 XLT 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I recently replaced the spark plugs in my '00 5.0. After I noticed the hard starts, I pulled a plug and they looked pretty bad. I think that they were the originals, and lasted 45k miles.
The plugs looked pretty bad. The tips were well worn & rounded, and the gap looked pretty big. Nothing out of the ordanary, just worn. Most of the platinum tips on the ground had worn/flaked off.
The old plug was a Motorcraft Platinum AWSF 32E. The "factory replacement" (according to Auto Zone) are the Motorcraft Platinum AGSF 32FM. Not sure the difference, but physically, the electrode on the new plugs is much narrower and longer, and there wasn't a noticeable platinum tip on the ground. Does anyone else have experience or information regarding these plugs?
What surprised me was the recommended gap is .054". I set that gap to all of the plugs and installed them. On a hunch I checked the well-worn used ones that I had pulled out. All of them were under .060". They looked much worse than that, and I expected them to be at a wider gap. Were they set to .054" from the factory? or a different (smaller) gap because they were a different part number?
Once replaced, the X seemed to run a little better; start easier, idle smoother, better throttle response, etc. I paid about $4 each per plug. The install went smooth with a spark plug socket, 3" extension, and a 3/8" drive rachet. I did the driver's side from the top, and the passanger side through the fender (I didn't remove the tire, but did unclip the mud shield from the fender liner). Took less than an hour total in the driveway.
I'll keep an eye on the plugs and post if anything strange pops up, but I don't expect anything. The next time I change the plugs I'll proabably use the same type, as well as replace the wires.
Hope this helps!
-Brad
Oversquare is offline
( Join the Elite Explorers )
Old 07-14-2004, 12:41 AM   #2
Garth
Mt Vernon NY
98 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
A few months ago I got the same plugs from my retailer. I was hesitant because the numbers did not match the original so I checked with the motorcraft site and they recommend the same. They work fine for me also and my original plugs were very worn also (66,000miles on them). I did my wire the same time because they were done in too. This week I will have to do my ball joint because they are knocking and squeaking like crazy. They too have been revised and instead of the original multi-piece for the passenger front its now I single v-arm.
Garth is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
