#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Ham Radio - CB - Trail Communications
Notices
Ham Radio - CB - Trail Communications I have found that fourwheeling and ham radio go hand in hand. Post any questions or comments about the great hobby of amateur radio here. Of course CB'ers are welcome also. Ray, AE6H and Joe, N1LVN both moderate this forum.
Sharp CB-2460?
Reply
Thread Tools
Old 07-19-2004, 01:15 AM   #1
agzaretzka
Elite - G-d Bless!
Kennewick, WA
agzaretzka's Avatar
1991 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Sharp CB-2460?
I've had this CB radio in my garage for about fifteen years, and know nothing about it (or CB in general). Now that I have an Explorer, I'm wanting to add this CB, assuming it works. So, is this a good model? reliable or problematic? etc.....
I understand the volume, squelch, and channel controls, but what are the ANL (on/off) and DELTA (+/0/-)? (As I said, I have no experience with CBs, except what I have been reading here). It has a little signal power meter on the front; how is that used? Also, on the back, it has an external speaker connector and a PA speaker connector. How do they differ? only in that the external connector disconnects the internal speaker and the PA runs in conjunction with? or ...?
And, anyone know what year(s) this was actually made?
Tomorrow I'll start cleaning it up and see if it works.
Thanks for all the help!
agzaretzka is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-22-2004, 02:37 AM   #2
Ray Hutchinson
Moderator Emeritus
Dana Point, CA
Ray Hutchinson's Avatar
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
Question
agzaretzka,
Sorry, I have never seen or even heard of Sharp making CB radios, but maybe others have. Is it a 23 (old style) or 40 channel (newer) radio, Obviously, a 40 channel radio is more desirable so you can find a channel that isn't too busy that you can use in common with the group or area you're running in. If local custom or group preference is to use one of the channels 24 thru 40, and you only have a 23 channel radio, you're SOL.
AS for the "ANL" that is the Automatic Noise Limiter, a circuit that reduces the intensity of some types of recieved static, especially sharp pulses like spark plug "pop". It doesn't do anything for transmit. Most folks turn the ANL on and leave it on.
The Delta tune is usually a type of fine tuning that allows you to shift the reciever i.f. section slightly up or down in frequency to compensate for a recieved station that is slightly off frequency, or to reduce a frequency specific type of static. You can shift up or down slightly to improve the quality of the recieved signal.
Hope this helps, and let us know if you get it working and/ or have more questions
__________________
Ray, & Debby Hutchinson, AE6H
AKA: Pack Rat
'93 White XLT, Modified, lotsa radios
'06 F250 SD Dsl (Big Red 'Plorer Puller)
'01 Lincoln LS-V8
'66 'Stang CA Sprint
Ray Hutchinson is offline   Reply With Quote
Old 07-26-2004, 02:17 PM   #3
agzaretzka
Elite - G-d Bless!
Kennewick, WA
agzaretzka's Avatar
1991 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the info. Its a 40 channel - I would not have bothered if it was older
Seems to be working fine; not being familiar with CBs I don't know if the amount of static I have is close to normal or not. Also tested with external speaker, and PA works too. It fits nicely in the ashtray slot; just need to make some trim for it. Hard part is deciding where to mount the antenna. I know the best is up top, but I'm leaning towards putting it in place of the am/fm antenna. . . .
Old 08-20-2004, 10:42 PM   #4
agzaretzka
Elite - G-d Bless!
Kennewick, WA
agzaretzka's Avatar
1991 EB
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Antenna Mounted
I like the look; seems to work ok too....
Old 08-09-2009, 01:17 AM   #5
nbfinsen@aol.com
Bristol, PA
Vehicle Specs
Quoted: 0 Post(s)
I used to have an old Sharp CB (they didn't make many, & not for long), one of the best little radios I ever owned. I don't remember mod #, mine had nice easy-grip rubber knobs. Had it in my "big-truck" back in the early 80s, nice rugged l'il radio, "talked" pretty good too. My advice; get you a magnet-mount K-40 antenna (they come pretty well matched right outta the box) & put it in the middle of the front 1/3 of your roof & if the radio doesn't have a "mic gain" (I don't think it does) get an Astatic "Red Devil" pre-amp mic for it, or if it does, get Astatic's noise canceller stock mic for it & use the mic-gain pre-amp in the radio to raise & lower your modulation (voice). If it still works you got a good l'il radio there.
nbfinsen@aol.com is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
