Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
check engine light
Reply
Thread Tools
Old 07-25-2004, 10:24 PM   #1
fishmac135
Fort Worth, TX
'94 XLT
Vehicle Specs
(Original Poster)
check engine light
My 94 explorer has a check engine light after it has been running for a couple of minutes. I have never owned a Ford before this one so I don't know what to do first. In the past I could retrieve codes from my chevy by installing a jumper wire in the ALDL, but I don't even know where to start on my explorer. I don't take my vehicles to the shop because I can usually fix them myself. Can somebody point me in the right direction?
fishmac135 is offline   Reply With Quote
Old 07-25-2004, 10:35 PM   #2
jayhawkexplorer
Mission, Kansas
jayhawkexplorer's Avatar
'97 XLT
Vehicle Specs
You can buy an OBD-I scanner for relatively low price, like less the $50 or you can go to Advance Auto Parts or AutoZone to have them scan it. O'Reilly does not scan, at least the ones here don't. Just remember that a CEL code can mean a lot of things and its not necessarily the problem you think it is. For example, it may tell you that your oxygen sensor is bad when the problem really is that you're running rich and the sensor is reading bad because of it. CEL's are tough to diagnose but a scanner is a good way to start. Welcome to the site, try the search function, it will yield a ton of info because with 26,000 members, chances are somebody's had the same problem you have at some point.
__________________
Former owner of a '97 Explorer XLT, I let her go on 5/31/06
Had a Mazda Protege5 for 32 days before it got totaled by a fellow driver, now owner of an '03 Mazda 6s.
jayhawkexplorer is offline   Reply With Quote
Old 07-25-2004, 10:41 PM   #3
Robb
Vehicle Specs
If you pick yourself up a Haynes manual, there is a procedure for creating a jumper to get the codes, and a list of what the codes mean. This is the $13 way of doing it. A Haynes manual is a great investmest in general for your vehicle.
The $35 way is to pick up an OBD-I reader at Wal-Mart or an auto parts store, and use that.
Robb is offline   Reply With Quote
Old 07-26-2004, 01:49 PM   #4
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
One easy to follow description of the KOEO test can be had at www.fordfuelinjection.com
A more complete description of both the KOEO and KOER tests can be had at www.dalidesign.com/hbook/eectest.html
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
