Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
won't pass smog, error code P1450
Reply
Thread Tools
Old 07-31-2004, 03:00 PM   #1
merc
orange, ca
97 mountaineer
Vehicle Specs
(Original Poster)
i'm still lost, error code P1450
any ideas? my regist. is past due (dmv never sent notice), and i need smog, but it failed due to check engine light and error code P1450. i looked up the code, and learned it was "Inability of Evaporative Emission Control System to Bleed Fuel Tank." great. i have no idea what that means or what i need to do to fix it. anyone have any ideas? Ford dealer wants $95.00 to diagnose, plus however much to fix it (i am out of ajob as of the end of next week, so i'm trying to do this on my own). i have a '97 merc mountaineer w/93k miles, and i'm desperate.
merc is offline   Reply With Quote
Old 07-31-2004, 03:15 PM   #2
huskyfan23
Rah no Hans Bwix
WA
huskyfan23's Avatar
1994 XLT 4x4
Vehicle Specs
This thread may help.
http://www.explorerforum.com/forums/...ht=evaporative
__________________
1994 Explorer XLT
My registry entry: here
Diamond Everything w/ HID Bi-Xenon Projectors
I'm no doctor, but I am a self-proclaimed genius. There's no reason not to trust me.
What kind of dessert causes women to gain the most weight? Wedding cake
huskyfan23 is offline   Reply With Quote
Old 07-31-2004, 03:25 PM   #3
merc
orange, ca
97 mountaineer
Vehicle Specs
(Original Poster)
still confused!
thanks husky, i had checked there earlier, and just now revisited, but i'm still lost. i need specific info (i guess) for p1450. i found another thread that had one very specific description of how the diagnostic is poerformed by the cars computer. this only confused me more. i am hoping someone can tell me what things to try, and in what order, to diagnose what my problem is. i am new to the site, so sorry if i am going about this all wrong.
Old 07-31-2004, 03:31 PM   #4
merc
orange, ca
97 mountaineer
Vehicle Specs
(Original Poster)
still trying...
Old 07-31-2004, 04:27 PM   #5
Brain
Golden, CO
'92 4X EB and '91 4X XLT
Vehicle Specs
The code means that there is too much vacuum in the gas tank. Cheapest possible fix is replacing the gas cap. Try this first. Be sure to clear the fault code from memory after you change anything so that you are not reading a stored fault code that is no longer a problem.
Brain is offline   Reply With Quote
Old 07-31-2004, 04:31 PM   #6
merc
orange, ca
97 mountaineer
Vehicle Specs
(Original Poster)
thanks brain. i'll try that right now. will disconnecting battery for a few minutes clear the code??
Old 07-31-2004, 04:41 PM   #7
huskyfan23
Rah no Hans Bwix
WA
huskyfan23's Avatar
1994 XLT 4x4
Vehicle Specs
Quote:
Yeah, disconnect the negative for 15-30 minutes.
__________________
1994 Explorer XLT
Old 07-31-2004, 05:08 PM   #8
Brain
Golden, CO
Vehicle Specs
I'm not sure, but my Fords (92-94) use EEC-IV ststem and code reader, and there is a way to erase the contiuous fault codes by switching the code reader to HOLD while it is starting to read the KOEO codes...I don't know if this has changed (it might be a time saver).
Old 07-31-2004, 06:16 PM   #9
merc
orange, ca
97 mountaineer
Vehicle Specs
(Original Poster)
thanks for the tips guys. i've slathered some pet. jelly on the gas cap gasket, and i reset the computer (i think, it certainly cleared the radio), so i'll see if the CEL comes on again. if it does, could it be the o2 sensors? i was told there are 4 of them. brain, i don't have a code reader, but thanks. i'll post again after i do some driving.
Old 07-31-2004, 06:37 PM   #10
SiLenZe
Milwaukee, WI
'01 Sport
Vehicle Specs
Arrow
problem:
P1450 - Unable to Bleed Up Fuel Tank Vacuum
Monitors the fuel vapor vacuum and pressure in the fuel tank. The system failure occurs when the EVAP running loss monitor detects excessive fuel tank vacuum with the engine running (but not at idle).
things to look for:
Blockages or kinks in EVAP canister tube or EVAP canister purge outlet tube (between fuel tank, EVAP canister purge valve and EVAP canister)
Fuel filler cap stuck closed (no vacuum relief)
Contaminated fuel vapor elbow on EVAP canister
Restricted EVAP canister
CV solenoid stuck open (partially or fully)
Plugged CV solenoid filter
EVAP canister purge valve stuck open
VREF circuit open (harness near FTP sensor, FTP sensor or PCM)
Damaged FTP sensor
__________________
-SiLenZe
http://www.geocities.com/silenze99/
SiLenZe is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
