Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
clutch back together but cant get system bled
Reply
Thread Tools
Old 08-01-2004, 08:34 PM   #1
irishpilot
boise
92 explorer 5spd 4x4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi,
I am helping my brother with his 92 5sp. we have done the clutch and put in a new slave cylinder. We have the Haynes manual and we have tried to do it the way it explains but get no pedal pressure and only dribbles of fluid comes out.
we have it all together pretty much, but this is beating us.
any tricks to this or any thing that can help us?
please help me asap, any input is appreciated.
irishpilot is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-01-2004, 08:41 PM   #2
mechanic021
mechanic021's Avatar
Vehicle Specs
Quoted: 0 Post(s)
this may sound really dumb and dont know if its related to the explorers but is the battery hooked up? I work at a tranny shop and we once did a clutch on a 95 f150 and we tried and tried to bleed the clutch. then we saw the battery was unhooked. We hooked it up and the cutch bled out just fine.
mechanic021 is offline   Reply With Quote
Old 08-01-2004, 08:57 PM   #3
lonestar
lou,ky
91 XLT, 02 XLS
Vehicle Specs
Quoted: 0 Post(s)
Mity-Vac
I hear this is best way.
__________________
Make sure you have a left handed screw driver, thats the only tool for the job.
lonestar is offline   Reply With Quote
Old 08-01-2004, 09:27 PM   #4
irishpilot
boise
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
no battery hookep up... well try it
what is a mity-vac?
update: We have the fluid coming out strong now, but still no pedal pressure?
when we installed the slave cylinder, my brother unbolted the old one (2 bolts), then bolted the new in. I put the o ring on the male adapter for the hydralic line, and it is cliped into place like the haynes decribed, did we miss anything?
will try the batter and be back.
thanks for the replys
Old 08-02-2004, 10:18 AM   #5
irishpilot
boise
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Anymore Help Out There?
Old 08-02-2004, 09:54 PM   #6
Doug
I'm Awesome!
Home is where the Army tells me. Right now it's Manorville, NY
Doug's Avatar
2006
Vehicle Specs
Quoted: 1 Post(s)
There is a specific sequence to bleeding the clutch you have to follow, When i did my clutch last year i had the same problem. The process is outlined in either a haynes or chiltons manual if you can get your hands on one of them. I unfortunantly dont remember the exact process, basically you have to press the clutch to the floor and release it real fast like 10 times and keep doing it till it's blead. If you do a search you should be able to find the info here on the board. good luck.
__________________
97 Explorer
Life's hard. Wear a helmet.
Doug is offline   Reply With Quote
Old 08-24-2004, 03:31 PM   #7
yluahale
Waialua, Hawaii
1991 explorer
Vehicle Specs
Quoted: 0 Post(s)
Hi Im having the same problem right now, the quick disconnect is the problem for us. Im attempting to find away to loose the qd coupling and use a regular coupling. Apparently when you replace all those parts and do any work with the hydraulics you should replace the hydraulic line because the qd coupling holds air that is almost impossible to bleed. Try replacing the line and coupling. Im still searching for a way to loose the quick disconnect all together, anyone have a clue?
yluahale is offline   Reply With Quote
Old 08-24-2004, 03:34 PM   #8
yluahale
Waialua, Hawaii
1991 explorer
Vehicle Specs
Quoted: 0 Post(s)
Same delimma
Old 08-24-2004, 04:17 PM   #9
Josh
Virginia Beach, VA
Josh's Avatar
1991 4 Door Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Don't know if it will help, but, back to the F-150. I replaced my slave cylinder on my 92 F-150, and it was self bleeding. I had to pump the clutch for about 15 minutes to get it bled. I pumped so much, that I was getting nervous. I just don't know if the Explorer clutches are self bleeding or not.
__________________
"NEVER INTERRUPT YOUR ENEMY WHILE HE IS MAKING A MISTAKE" -Napolean Bonaparte
Josh is offline   Reply With Quote
Old 08-24-2004, 04:33 PM   #10
Ford_Racing_Guy
Spencer, Wisconsin
'92 XLT & '98 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
yes it certainly is a pain in the ass, its quite a long series to bleed the clutch, just did that to my brother's ranger awhile back, i have a printout of it somewhere i'll see if i can find it and then i'll post it here if need be
__________________
1998 XLT
98 F250 XLT L/D
97 Ford Thunderbird LX
06 Yamaha R1
Ford_Racing_Guy is offline   Reply With Quote
Old 08-28-2004, 10:39 AM   #11
anthonytony
KNOXVILLE TENN
2000 sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
had this same problem with a 94 it was a bad slave,leaking inside.
anthonytony is offline   Reply With Quote
Old 08-28-2004, 12:07 PM   #12
KPT
NC
'95 XL 4x4
Vehicle Specs
Quoted: 0 Post(s)
I couldn't any pedal pressure at all on mine when I changed it. Ended up letting it sit overnight and most of the air worked itself out.
KPT is offline   Reply With Quote
Old 08-28-2004, 01:05 PM   #13
XonDubs
wisconsin
97 5.0 AWD Limited
Vehicle Specs
Quoted: 0 Post(s)
this may sound dumb but when i changed the tranny,clutch,flywheel,and slave cylander on my probe i was suiping up the pedal didnt have much pressure, i found out i had to adjust the clutch pedal line.....you could try that, if you can....other wise i dont know lol
__________________
97 Ivory Explorer Limited 5.0 AWD.
2008 Scion XB-Grocery getter
XonDubs is offline   Reply With Quote
Old 08-28-2004, 09:11 PM   #14
Josh
Virginia Beach, VA
Josh's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Dubs,
There is no line per say. It hydralic if I'm not mistaken.
__________________
Old 08-28-2004, 09:13 PM   #15
Josh
Virginia Beach, VA
Josh's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Never mind, I think you know that already. Its late and Im tired.
__________________
Old 08-29-2004, 12:16 AM   #16
91EXNM
NM
91EXNM's Avatar
91 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
This is pretty much the same problem we r having, but were able to bleed the clutch get pleny of pressure but no pedal to speak of.. and result is ... no gears and we aint movin..... ergo we r dead in the water here.....
__________________
1991 XLT 4x4 NM EXPLODER, 5.5" Superlift w/ Extended Radius Arms, SuperLift Dual Shock Mounts, 3" PA BL, Superruner Steering, 35x15x12.50 Dunlop Mud Rovers, 15x10 MB Rims, Perry's Fab&Fiber Fiberglass Baja Front Quarter Panels, Pioneer Premier Head Unit, Dual 10" 1000 Watt Subwoofers, 900 Amp Rockford Fosgate Amplifier & Coming soon a 4.56 regear
MY Before and After Pics - http://www.zianet.com/amhi/exploder/index.html
91EXNM is offline   Reply With Quote
Old 09-17-2004, 03:29 AM   #17
FordLover
Houston, Tx
'02 XLT
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Ugg, sign me up... same problem.. all new clutch, slave. put it all back together, and pedal feels like it's connected to NOTHING.. grr.
Even followed the process in haynes manual, no luck.
Anyone resolve their problem?
__________________
'02 XLT V8 4x4 tow pkg - sometimes pulling our camper
'07 Infiniti G35 Sport Sedan 6 speed
'13 Ford Edge Limited (wifes)
GONE: '94 Sport, '91 XLT, '92 XL 2dr 4x4 33's lifted
FordLover is offline   Reply With Quote
Old 09-17-2004, 11:57 AM   #18
fordby4
Santa FE New Mexico
92 xlt
Vehicle Specs
Quoted: 0 Post(s)
when i put a new slave in my x i had the same problem. When i would go to bleed it I would get nothing just little drips at at time. I didnt figure it out for two days and then when my dad came over to help me he saw that I had the cap on the clutch resevoir with the little black thing inside and he told me to take it off and I did and the first time we bled it the clutch went from no resistence to plenty within 20 pumps of the clutch so I dont know if this will help but it worked for me.
fordby4 is offline   Reply With Quote
Old 04-15-2009, 07:29 PM   #19
doubletfarm
MN
Vehicle Specs
Quoted: 0 Post(s)
WEll, I'm trying to read some of the former posts but keep getting flipped to this screen to post before I can read other posts. So HI
doubletfarm is offline   Reply With Quote
Old 07-08-2009, 11:55 PM   #20
whitetrashfab
Tenino, WA
91 sport
Vehicle Specs
Quoted: 0 Post(s)
This may sound stupid but the best way I found to bleed the clutch system is to drill out an old clutch res. cap and put schlader (sp?) valve in it right where the little breather hole used to be (I used one off the fule rail on a spare 4.0L I had laying around). Just add a little air and it will force the air out of the system that is traped without having to bench bleed or remove the master from the fire wall to get it lower in the system while bleeding. Just dont force all the fluid out! Basicly its a poor mans power bleeder. Just bleed the system untill you get fluid at the slave, top the res. off and put the cap on. Add a little air pressure to the system and have someone push the clutch in while you open the bleeder valve, it will force the air bubble right out of the system... Good luck!
whitetrashfab is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
