Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
anyone tried a jeep cherokee spare underbody
Reply
Thread Tools
Old 08-06-2004, 04:20 PM   #1
N2FORD
Kingston,TN
N2FORD's Avatar
2001 Sport Trac 4wd
Vehicle Specs
(Original Poster)
Question anyone tried a jeep cherokee spare underbody
I was thinking if I put the jeep cherokee mini temporary spare tire underneath I could run a tailpipe out the drivers side. Also would look neater from the back since it would go further up and would not be seen from the back. Any comments for or against????
__________________
01 Sport Trac 4wd-long term plans of V8 and SAS
94 Mustang GT convertible
N2FORD is online now   Reply With Quote
Old 08-06-2004, 04:27 PM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
just make sure it can take the weight and also is the same diameter tire. The wheel bolt circle should be the same as your Explorer.
Other then that there is no reason not to
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 08-06-2004, 04:44 PM   #3
Robb
Vehicle Specs
I did the opposite with my wife's Jeep, I pulled her doughnut out and slapped an Explorer spare back there.
The GC spare is good for 2300lbs, the BP is the same, and the rim is so skinny that the BS shouldn't matter. You would just have to make sure that it ends up on the front whenever you put it on.
Also, if you did it, I would throw the real spare in the back when you go on longer trips. Dealing with a doughnut spare while on the interstate is a PITA.
Robb is offline   Reply With Quote
Old 08-06-2004, 07:09 PM   #4
N2FORD
Kingston,TN
N2FORD's Avatar
2001 Sport Trac 4wd
Vehicle Specs
(Original Poster)
Thanks for the responses, I will be putting 18's on soon and using different front and rear sizes. I know that with the limited slip rear i will have to be careful about the tire sizes side to side.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
