| Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Melbourne, Australia
1999 XLT 4wd
Multipoint Sequential Gas Injection?
Does anyone know much about these gas systems and how well they work on Explorer's? I don't mean gasoline either, but LPG (Liquid Petroleum Gas). I am considering converting mine to gas and wanted to find out as much as possible. From what i've found out, these systems are required when the car in question, has a plastic manifold. Explorers have plastic manifolds so obviously this is the system to go for. Sequential is required so that the engine doesn't backfire and blow the manifold to bits.
For one, i'd like to know if anyone actually makes a system for these cars and more importantly, how does the rest of the engine cope with gas. Will the valve seats handle running on gas? From some searching i've done, it appears that some Explorers came out with factory gas. I wonder what system these cars had? __________________ 1999 Explorer XLT, TJM 40mm lifted leaf springs, 40mm torsion bar lift, 32" BFGoodrich Mud Terrains, Rancho RS9000's, TJM Polished Alloy Bullbar, Hella Rallye 4000 driving lights, K+N air filter, Piranha dual batteries, GME Electrophone CB and UHF radios, Auburn Gear LSD in rear, 4.56 diff ratios and 2" bodylift kit. |
#2 |
Boston Ma
97 Eddie bauer
I know in my area public transportation vehicles, and fleet vehicles for natural gas companies usually have converted their trucks to use natural gas. See if you can talk with someone there. Im sure the natural gas comp. would love to see you convert and give you info. Let me know how you make out.
Jay |
#3 |
High Voltage.
Erie, Pennsylvania
1998 Mountaineer
I've seen kits labeled especially for the Explorer. I looked into it a little bit, as I was considering doing the same thing. The kit I saw was a little pricey at 2000. Motors run well on propane, polute less, generally cost less to run, but I do think they have slightly less power than stock gasoline. They can also run in any angle, even upsidedown
__________________ 1998 Mounty 5.0 AWD TT/Shackles/rear AirLift springs 31x10.5 Kelly TSR's 1995 Subaru Legacy AWD Sedan RIP---Killed by an suicidal deer 1972 El Camino---Project Dirty Old Chevy---Fresh Marine Longblock .060 over, Forged crank RV Cam 454/th400 swap, Hooker Headers, fresh coat of white 1999 KTM 300exc RaceTech Suspension, Rekluse Slipper Clutch, single track killer |
#4 |
Brisbane Australia
1997 Limited
Adam,
I'm in the same place you were in August last year, looking around for answers. Your valve seats will handle LPG 'cause they are hardened for unleaded. About the plastic manifold, you can fit a blow off valve or even something as simple as a rubber grommet to releave pressure in the manifold. It shouldn't be a problem if you start on petrol and switch to LPG. Anything you have found out about injected gas would be welcome. Ford brought out dual fuel Falcons that had LPG injection, I wonder that set up can be modified to fit? |
#5 |
Sykesville, MD
'00 XLS, '03 Sport
I think a person or two in the UK run LPG in their Explorer's. Hopefully one of them will chime in.
__________________ 2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body My 2000 Explorer |
#6 |
Ajax, Ontario, Canada
1998 Limited
Seems to me like a lot of folks in Europe run LPG. The way our fuel prices are going, it may not be long untill we do too!
__________________ I'd rather have a full bottle in front of me, than a full frontal lobotomy. |
#7 |
cambridge uk
1996 dunno
hey there
![]() well got my 97 explorer converted over to lpg using a multi point sequential injector system by bi gas of belgium,so far so good..running a lil rich at the moment but it takes about 1000 miles for the rig to "bed in" doesent seem to be any huge changes performance wise,hangs in the 5500-6000 rpm area for about 1 second longer than when running with petrol when the gears shift as you get the kickdown but thats manageable..looks like she's doin about 240-60 miles per 55 liters of lpg(got a 70 litre tank and in line with safety regs only fill it to 80%) havent taken it on a big cruise yet but doin a few hundered miles tomorrow with lots of motor way so i'l let ya know how it go. basically the dude who did the conversion droppe dhte spare wheel out and replaced it with a 70 litre lpg spare whel shaped tank and put the filler in the passenger side rear bumper(sorry..fender,heh heh) got a lil box on the dash with 5 led lights one red 4 green each representing roughly (very roughly if you ask me) a quarter tank as the lights go out well thats self explanatory,when its on the red i got 15ltrs reserve and when it finishes up the lpg it makes a bleepin noise you hit a button to agknowledge it and shazam back to regular petrol with out missing a beat..couldnt be simpler. as for starting,you just start as normal with petrol then as the engine warms up to 25 ish degrees c i thin,it automatically swithches to lpg and your away..as long as its fitted by an approved installer ythen no adjustments to your insurance. hope that helps,any q's just ask. rgds. RH76
#8 |
cambridge uk
1996 dunno
just to update,the system is all run in now,been back for tune up and the initial loss of growl has been regeined..no drop in performance at all..on long runs doin 200 miles for every 13 gallons..not brilliant but consider that to fill up 60 litres of fuel costs me 22 quid!! would cost 60 quid if just on petrol now.hope this inspires suome other xplorers to jump on the lpg bus..beleive me you wont be sorry.
peace RH76 |
#9 |
Mississauga, ON
1992 XLT
LPG Kit?
Does anyone know where we can get this done or buy the kit in the US or Canada? www links, tel number?
Thanks! |
#10 |
cambridge uk
1996 dunno
http://www.bp.com/modularhome.do?categoryId=4060&contentId=7001891
this wold be a good place to start. rgds RH76 |
#11 |
cambridge uk
1996 dunno
http://www.shellgaslpg.com/site/page/11/lang/en
http://www2.dps.state.la.us/LPG/public/home.htm nice links from the lousiana site there. good luck,im telling you you wont regret it if you convert. RH76 Edit: Links fixed Last edited by Maniak; 09-07-2005 at 10:53 AM. |
#12 |
97-00 HHI, SC ************ 00-02 Boston, MA********** 02-04 Augsburg, GERMANY 04-now Munich, GERMANY
'97 Eddie Bauer
I converted my X to run on LPG back in March. It worked out pretty well and I never regretted doing it.
Here are some pics: Quakecom __________________ '97 Explorer Eddie Bauer V-6 4.0L SOHC Burgundy w/ tan interior --> Mods: K&N FIPK, German H4 Headlights, Saleen Front and Rear sway bars, custom front seat head rests --> DONE : LPG Gas System, 18x8.5 Altera Rims with 285/50/18, EE Lowering Kit, Bilstein Shocks, 6000K H4 Bi-Xenon--> SOON TO COME: Car-PC w/ 8" Touchscreen |
#13 |
Boston Ma
97 Eddie bauer
Where did you get your kit from and what did you pay?
#14 |
'97 Eddie Bauer
I got it installed here in Germany. Its a Lando Renzi Omega system (the best on the market ASAIK) and it was about $2k (installed).
#15 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
It's hard to tell from the picture, but where are those 6 fuel injection hoses connecting to? They look like they are going onto the manifold. Was the original manifold removed, replaced, or modified? Could this kit be transferred to any 6 cylinder multiport fuel injected vehicle?
#16 |
Ontario, Canada
06 F150 SC 5.4
The exploders ol system was also a Lando Renzi, not sure what version but i remember the control for gas/nat gas had that name. We couldnt start in natural gas mode but i think that was because there wouldnt be enough air flowing into the intake to take the gas just turning over with the starter.
You might regret it if you have to get the tanks recertified every couple years though im not entirely sure for propane, but also natural gas tanks were extremely heavy. __________________ 2006 F150 XLT Supercrew 5.4L 1994 XLT 4.0L 1997 XL 4.0L |
#17 |
Brooklyn, NY
According to what they said in the other post, they also had to start with regular gasoline, then switch over. When I was experimenting with a home made system, I had to do that too. This one has it's own separate multiport system bypassing the original injectors.
#18 |
Ontario, Canada
06 F150 SC 5.4
It would be pretty awsome to be able to start up on it, and perhaps convert the vehicle entirely..
| Thread Tools | |
