Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Rough vibration when stopped
Reply
Thread Tools
Old 08-16-2004, 12:43 AM   #1
explorer82184
plano,tx
2001 explorer sport
Vehicle Specs
(Original Poster)
I recently purchased a 1998 eddie bauer and I am having a strange problem with it. The car is new to me and has about 80,000 miles on it so Im not sure what has been replaced. Anyway, whether the engine is warm or cold, when i come to a stop, the engine shakes and vibrates. Sometimes it gets bad enough where it shakes the car but only when I come to a stop, once i accelerate and get going, everything runs smoothly. Also, when the car begins to vibrate, the rpms rise even though I have my foot off the gas. It doesnt happen all the time, just a majority. What do you guys think? Anyone had this problem before?
explorer82184 is offline   Reply With Quote
Old 08-17-2004, 02:44 AM   #2
explorer82184
plano,tx
2001 explorer sport
Vehicle Specs
(Original Poster)
no one?
Old 08-17-2004, 07:15 AM   #3
rhyno
Potomac, MD
rhyno's Avatar
1997 EB
Vehicle Specs
Mine does this too. It is not too bad, and I attribute it to the fact that I now have about 130000 miles. I tried cleaning the MAF, but I dont really know if it helped. Next time I get a couple hours free, I think I will try swapping in some new plugs and wires.
__________________
2002 Limited
1997 Eddie (SOLD)
rhyno is offline   Reply With Quote
Old 08-17-2004, 10:21 AM   #4
Pheonixx77
NY
02 sport trac
Vehicle Specs
does it want to stall? if so its a vaccum leak. mine did something real similar once before. the engine seemed as though it wanted to shake out of the truck. one of the vaccum lines came off at the intake. you can fix it with some zip ties after you get the vac line back on.
__________________
Pheonixx77 is offline   Reply With Quote
Old 08-17-2004, 01:02 PM   #5
explorer82184
plano,tx
2001 explorer sport
Vehicle Specs
(Original Poster)
yes, it does act like it wants to stall, I will check the vacuum lines and see if their is a leak, thanks for the input!
Old 08-22-2004, 01:43 PM   #6
explorer82184
plano,tx
2001 explorer sport
Vehicle Specs
(Original Poster)
I checked the vaccum lines and everything seems to be ok, no leaks. This has stumped me! What is wrong with my car??!?!?!
Old 12-04-2012, 07:23 AM   #7
rob3302
Staten Island, NY
1997 Explorer XLT
Vehicle Specs
My car does this too, although it does not seem like it wants to stall. It is more noticable now after i cleaned the throttle body. Im going to change the pcv valve and clean the maf sensor this weekend. Any other ideas that may help????
rob3302 is offline   Reply With Quote
Old 12-14-2012, 08:58 AM   #8
PJCanadaXLT
Alabaster, AL
1998 Ford Explorer XLT
Vehicle Specs
Rough Idle
My 98 explorer xlt with the SOHC was giving me this problem for a while and i replaced the upper and lower intake manifold gaskets and it fixed it. $17 for the set at Advanced Auto Parts. or you can go to the dealer, wont be much either way. good luck.
PJCanadaXLT is offline   Reply With Quote
Old 12-14-2012, 09:30 AM   #9
Kevlar7R
Phoenix, AZ
Kevlar7R's Avatar
1997 Mountaineer 5.0 4x4
Vehicle Specs
Start with the basics, air filter, clean the maf and throttle body and iac. The air flow at idle is very small, so it doesn't take much dirt to affect it. When throttle is open, your flowing so much air that small stuff like dirty bits don't have as much affect.
__________________
ZAPV X76
ZAPS 1
1997 Mercury Mountaineer 5.0. 4406 swap, tt and shackles, Falken Wild Peak 31x10.5x15 on stock rims. 9000lb hidden winch. In dash 7inch dvd/gps nav/ bluetooth. Custom bumpers and body lift coming!
Kevlar7R is offline   Reply With Quote
Old 12-14-2012, 09:44 AM   #10
Falconkeeper
Tulsa. OK
"96 XLT
Vehicle Specs
If the vibration goes away when you increase revs above 1000 rpms, you might want to check the flexplate. The vibration got so bad, I thought the engine mount had broken. Search under flexplate to see if the symptoms fit.
Falconkeeper is offline   Reply With Quote
Old 12-15-2012, 11:29 AM   #11
rob3302
Staten Island, NY
1997 Explorer XLT
Vehicle Specs
I've read about the Intake Manifold Gaskets and I know the parts themselves are pretty inexpensive. Is it a difficult job to undertake considering that I am relatively new at working on my car? Is there anyway I can check to see if I actually need new gaskets??
Old 12-15-2012, 11:31 AM   #12
rob3302
Staten Island, NY
1997 Explorer XLT
Vehicle Specs
I will also look into the flexplate to see if that is the issue. Thanks for all the help. This forum is better than any book you can buy.
Old 12-15-2012, 12:42 PM   #13
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
Check for trouble codes BEFORE guessing, buying, and replacing parts. GL
http://www.explorerforum.com/forums/...55&postcount=2
swshawaii is offline   Reply With Quote
Old 12-22-2012, 08:37 AM   #14
OneofMany
Georgia Mountains- Talullah Falls
94 expl 4x4
Vehicle Specs
def check for vacuum leaks and check your codes, check your Maf and Map sensor, check ingnition wires and plugs. Im working on the same issue atm.
OneofMany is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
