Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Squeeling engine
Reply
Thread Tools
Old 08-16-2004, 07:31 AM   #1
Danimale
Woodstock, GA.
99 XLT
Vehicle Specs
(Original Poster)
Squeeling engine
First of all hello everyone!
For the past month or so there has been a "squeeling" sound under the hood. I thought belt at first but noticed the sound was from further back, towards the firewall but could not locate the source.
It squeels when started and continues intermittently untill I reach around 40mph or so, or I rev the engine. Also on the interstate travling up or down inclines. It is slowly getting worse. I crawled under the truck this morning to locate the sound, unfortunantly it wasn't squeeling at that time. I did look at my lower engine mounts. My driver's side had a little orange "post" next to the mount bolt, nut end. My passenger's side "post" seems to have sheered off.
Is this an indicator that I have a bad mount? Is there a fix, If not what else could it be?
Thank you much,
Dan
Danimale is offline   Reply With Quote
Old 08-16-2004, 11:03 AM   #2
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Could it be the idle air control valve. It is on the the intake manifold. It has a wire connection. Next time it squeels check it. It is a relatively cheap and easy repair.
unclemeat is offline   Reply With Quote
Old 08-16-2004, 05:53 PM   #3
Danimale
Woodstock, GA.
99 XLT
Vehicle Specs
(Original Poster)
Sorry about this, I don't think it is the mount. It's not the IAC but I'm sure glad you had me check it. The sound is emitting from right behind it. I only disconnected and reconnected a vacuum line that plugs into the (valve cover?). I took a picture, the arrow points to the vacuum line and I think I have the sound pinpointed to the circled area.
viewed standing at driver's headlamp
http://216.77.188.54/coDataImages/p/...80178/exp1.JPG
Anymore Ideas?
BTW I didn't fix anything but after I messed with the vacuum line it didn't squeel on my test drive, funny thing. I have a feeling it will return when I go to work tonight.
Thanks again,
Dan
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
