Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer - Ranger Tires & Wheels
Notices
Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here.
Balance issue?
Reply
Thread Tools
Old 08-20-2004, 08:19 PM   #1
Premier
Panzerfaust™
Utah
Premier's Avatar
96 sport
Vehicle Specs
(Original Poster)
Balance issue?
I have a vibration in the front end of my explorer. Thing is its only between 35-45/50 mph. If a tire was out of balance, it would constantly vibrate, no?
__________________
Rollover Posse Registry
CV Death Toll: 4
33x12.50 ProComp Mud Terrains on 15x8.5 Centerline Rims
6" Suspension, Locked Front/Rear, 1354 Manual T-case
ARB Snorkel, and Custom Pinstriping
Premier is offline   Reply With Quote
Old 08-20-2004, 08:35 PM   #2
Redrig
Gettysburg,PA
Redrig's Avatar
1997 Mountaineer
Vehicle Specs
Im 95% sure an unbalanced wheel wont vibrate untill a certain speed.
__________________
http://www.myspace.com/exforce
Redrig is offline   Reply With Quote
Old 08-20-2004, 08:49 PM   #3
Premier
Panzerfaust™
Utah
Premier's Avatar
96 sport
Vehicle Specs
(Original Poster)
Ok, thanks man. It pisses me off, because I bought my tires at 4WP and they were supposed to balance them. If they were closer, it wouldnt be so bad, but they are WAY far away. Never again!
__________________
CV Death Toll: 4
Old 08-20-2004, 08:54 PM   #4
Redrig
Gettysburg,PA
Redrig's Avatar
1997 Mountaineer
Vehicle Specs
What size tires did you get? When I put mine on I started having a vibration problem just like your describing and it isnt an unbalanced wheel. I had the balanced 3 times and roadforce balanced once and i still have the problem. I sure hope yours is an easy fix though. Goodluck.
__________________
Old 08-21-2004, 02:47 AM   #5
Fusion213
Jacksonville, NC
Fusion213's Avatar
'98 XLT 5.0L
Vehicle Specs
I had mine balanced where they used weights on both sides of the wheel. It helps a LOT with the balance situation.
I bought my tires/wheels from 4wp and they were balanced horribly, a very bad shimmy at roughly 45.
If you call up 4wp, they'll pay to get the tires balanced by another place.
__________________
98 5.0L SAS
Fusion213 is offline   Reply With Quote
Old 08-21-2004, 05:05 PM   #6
Premier
Panzerfaust™
Utah
Premier's Avatar
96 sport
Vehicle Specs
(Original Poster)
Redrig- I am running 33's. Procomp Mud Terrains.
Danny- What exactly did you tell them at 4wp? Did you just tell them that they are not doing the job, and you want them to pay for someone else to do it?
__________________
CV Death Toll: 4
Old 08-21-2004, 05:12 PM   #7
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
You sure it isn't a bearing?
__________________
1996 Explorer 5.0 V8 - TT/shackles, 31" BFG A/T - Registry thread
2005 Mustang GT - Sonic Blue
Hartman is offline   Reply With Quote
Old 08-21-2004, 05:43 PM   #8
Premier
Panzerfaust™
Utah
Premier's Avatar
96 sport
Vehicle Specs
(Original Poster)
I cant say for sure... I just replaced both sides upper/lower balljoints, outer tie rod ends, and an axle bearing. Is there an easy way to find if the wheel bearing is bad?
__________________
CV Death Toll: 4
Old 08-23-2004, 01:30 PM   #9
rikguy
Altoona, PA
96 XLT
Vehicle Specs
would a bearing do this only at certain speeds? I've been having this same problem for quite a while now and haven't figured it out.
__________________
..... Because I can !
rikguy is offline   Reply With Quote
Old 08-23-2004, 01:49 PM   #10
Hartman
Indianapolis, IN
Hartman's Avatar
1996 5.0
Vehicle Specs
When my drivers side bearing was going bad, it would make a whistling sound at lower speeds and quit above 25 or so.
__________________
Old 08-23-2004, 04:14 PM   #11
Premier
Panzerfaust™
Utah
Premier's Avatar
96 sport
Vehicle Specs
(Original Poster)
Hmm, no whistling sounds here. Just a vibration from 35-50ish. Above and below specified numbers, it stops vibrating.
Hartman, is there an easy way to tell if the bearing assembly is going bad? Like lifting the front end, or taking the wheel off etc?
__________________
CV Death Toll: 4
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
