#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
thermostat stuck open?
Reply
Thread Tools
Old 10-31-2004, 03:43 PM   #1
LAExplorer
Torrance, Ca
'97 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I wonder if someone can help me out... My engine will not heat up much past the low mark on the H2O temp gauge, even when towing. I think the check engine light is probably related to this issue. As far as I can tell, the thermo must be a "fail open" type. Is this the original thermo? I bought the X used so I'm not sure if this is a factory part or not. If I just go to the local parts store will the O.E.M. thermo also be a "fail open"? Do I have to order a special one? I like the safety of not having a $20 part turning into a $2500 problem. Other than guzzling more $2.60 regular gas than normal (and the heater never getting that warm) am I hurting anything? How do I reset the idiot light? I tried to unplug the battery but it didn't change anything. Thanks.
__________________
basically stock '97 XLT, 4-door, 4x4, 4.0 sohc
31x10.5's on stock alloy rims
Air-lift; Ride Control air bags
more to come... (aal, tt, shackles 33"+...)
LAExplorer is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-31-2004, 04:05 PM   #2
wired_af
Wichita, KS
'98 Sport
Vehicle Specs
Quoted: 0 Post(s)
I don't know about the "fail open" or whatever, but when my t-stat was stuck open I didn't get the CEL. If I were you I would just replace the t-stat and see if it fixes it.
__________________
Alex | '98 Explorer Sport 4.0L OHV 4x4
32's with 4" of lift.
Eclipse head unit and amps. Seas mids and LPG tweets.
wired_af is offline   Reply With Quote
Old 10-31-2004, 04:06 PM   #3
Robb
Vehicle Specs
Quoted: 0 Post(s)
Your stock t-stat will be a traditional "fail close" t-stat. But it is possible for it to stick open and stay that way. If you have a concern about the stat being to blame, go ahead and replace it. It will only run you about $5 + antifreeze.
To tell you the truth though, I have replaced the stat in my '95 several times, and the gauge always hangs out at the low end of the scale. The gauge just isn't very accurate.
Robb is offline   Reply With Quote
Old 10-31-2004, 06:05 PM   #4
unclemeat
Richmond, VA
unclemeat's Avatar
91 sport
Vehicle Specs
Quoted: 14 Post(s)
Are you getting lots of hot air out of the heater? Does the temperature of the air heat up after running the engine? That should tell you if it is the gauge or the termostat.
unclemeat is offline   Reply With Quote
Old 10-31-2004, 06:22 PM   #5
huskyfan23
Rah no Hans Bwix
WA
huskyfan23's Avatar
1994 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
I had one stuck open and my gauge wouldn't move much at all. You could also have a bad sender but I'd think it's the t-stat.
__________________
1994 Explorer XLT
My registry entry: here
Diamond Everything w/ HID Bi-Xenon Projectors
I'm no doctor, but I am a self-proclaimed genius. There's no reason not to trust me.
What kind of dessert causes women to gain the most weight? Wedding cake
huskyfan23 is offline   Reply With Quote
Old 02-01-2005, 01:04 PM   #6
jayhawkexplorer
Mission, Kansas
jayhawkexplorer's Avatar
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
Bringing back an old topic. I'm wondering if my thermostat is alright too. The outside temp has been in the mid to high 30's lately, and when driving on highway or in town, my temp gauge doesn't ever move much more then 1/5 of the way up the scale. I know in the '03 Ranger at work with the same gauge cluster, it moves to exactly halfway up and stays there. I've still got plenty of heat, except out of the far left vent, so I don't quite know what to think.
To answer another part of this question, you can buy a "fail safe" thermostat which will stay open when it fails. They cost around $11 but its well worth the investment, in my mind.
__________________
Former owner of a '97 Explorer XLT, I let her go on 5/31/06
Had a Mazda Protege5 for 32 days before it got totaled by a fellow driver, now owner of an '03 Mazda 6s.
jayhawkexplorer is offline   Reply With Quote
Old 02-01-2005, 05:03 PM   #7
LAExplorer
Torrance, Ca
'97 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I just changed the t-stat and found that the small arms that hold the thing together had completely snapped off, fortunately in the open position. I don't think modern t-stats can fail closed and the guy at Auto Zone said the same thing. The difficult thing, other than getting at the damn thing, is that there were 2 different stats spec'd for my year and engine (4.0 sohc, 1997), I know of no way to know which is which, before you have thing taken apart (mine turned out to be the bigger and nominally more expensive one, $8 vs. $15). Also, the idiot light stayed on for a short time after the install, but eventually it went out.
__________________
Old 02-01-2005, 10:48 PM   #8
jayhawkexplorer
Mission, Kansas
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
Don't trust AutoZone on anything. Those guys are for the most part, idiots. Cheap thermostats can still most definitely get stuck closed. That's why there's products like the "Fail Safe" line, which fail and stay open.
__________________
Old 02-01-2005, 10:56 PM   #9
Robb
Vehicle Specs
Quoted: 0 Post(s)
ALL thermostats, outside of Fail-Safe (and its couple of clones), ARE fail close thermostats. If it looks like a typical thermostat, it is fail close. The Fail-Safes look quite different.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
