Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
93 starter grind
Reply
Thread Tools
Old 11-07-2004, 03:48 PM   #1
squall01
St. Albans, wv
93 xlt
Vehicle Specs
(Original Poster)
93 starter grind
ok. for the past week or so, i could start it, but if i shut it off, and tried to start again, it would just click. thought it could be the battery, but it's showing good on the tester. changed the solenoid, still didn't fix it. then i got under it and "tapped" the starter with a hammer. this stopped the clicking problem. but when the engine would fire, it sounds like the starter doesn't disengage. so thinking the bendix in the starter is bad, i put a new starter on it. still doing it. any idea? thanks
bill
squall01 is offline   Reply With Quote
Old 11-08-2004, 11:00 AM   #2
Nick26
Cumberland, RI
98' 5.0 XLT
Vehicle Specs
i had a similar thing with one of my starters, the gear wasn't retracting but replacing the starter fixed it for me, is there a chance they maybe gave you another bad one?
the relay is fine and the ignition switch is fine i assume? can you do a amp/voltage check to see what kind of power is getting to the starter? bad battery connection or ground maybe?
Nick26 is offline   Reply With Quote
Old 11-08-2004, 11:03 AM   #3
squall01
St. Albans, wv
93 xlt
Vehicle Specs
(Original Poster)
well the thing is, it's actually starting the car, but sounds like it's not pulling the gear back or something. could the starter switch cause that?
Old 11-08-2004, 11:20 AM   #4
mrboyle
I Drive By Brail
Fruita, CO
mrboyle's Avatar
'96 XLT '80 Toy
Vehicle Specs
Quote:
If the starter quits cranking when you let go of the key, its not the switch or solenoid.
__________________
Mike Boyle
ASE Certified Master Tech.
'92 XLT(RIP) 1980 Toyota PU
Quote:
Originally Posted by DiffWackDaddy
Some people go looking for God, others get broadsided by them
mrboyle is offline   Reply With Quote
Old 11-09-2004, 06:48 AM   #5
Crankcase
Moderator Emeritus
Vancouver B.C, Canada
Crankcase's Avatar
1992 XL Ex-Police
Vehicle Specs
CAN
The starter is held in by two bolts...pull it out and check the teeth and flywheel. Report back.
__________________
*Explorer Family*
1992 XL Mine 1992 XL Sisters
1992 XL Dads 1994 XL Moms
Ex-Moderator: Modified Explorations Drivelines
New Member Forum
***Guest star poster....
Crankcase is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
