Oversquare
- June 14, 2004
- Wine Country
- '00 XLT 5.0 AWD
In the pursuit to improve the handling of the X, I purchased the Explorer Express Rear Sway Bar, as well as the Energy Suspension polyurethane bushings kit for the front sway bar.
My goal is to improve the handling, but not sacrifice ride quality or ride height/ ground clearance. I want a SUV that is safe to drive around town, during emergency maneuvers, and still be able to do light off-roading (i.e.: fire roads, snow, curbs, etc.). I don't want it to ride like a race car (already have one) or like an old Caddy.
One of my pet peeves about the Explorer is the rear end's tendency to "skip" or "hop" when cornering over cement seams and bumps at speed. This has occurred in both of my 2nd gen X's, and have heard it reported by others.
My other pet peeve is the tendency for the truck to "flop-over" in steering transitions, going from one direction to the other. It would seem like the X has to set in its lean before turning comfortably at speed. This is magnified when switching directions.
First impressions of the EE Rear Sway Bar are HUGE!!! I mean, my other X has the Saleen rear bar, but this dwarfs even that! I thought I overheard my front bar mumbling something about being inadequate (more on this later).
Install was straight forward. Remove stock bar, install EE bar. I did this in my driveway, without jacking it up, at night, solo. I would give this a 3 out of 10 for difficulty. The hardest part was lifting the heavy EE bar into place while snaking it through the leaf-springs and shocks. Another person would have made this process much easier.
The kit came with new bushings and grease. After 1k miles, no noises so far.
I was disappointed to find the stock end links are reused. These are not designed to transmit the additional torque into the bar and I think that these are a HUGE weak link in the system. The bushings are squishy and the shaft is very thin. They are a unique design and cannot be replaced with universal end links. I think there is more flex in the end links than there is twist in the bar, thus not utilizing the bar's full benefit.
Result? The improved handling is noticeable, but not as significant as I thought it might be for the size of the bar. Turns are taken flatter, and without as much push (understeer) as there is stock. The biggest benefit is the X does not "skip" or "hop" over bumps when turning at speed. This has been reduced to a very minimal amount, and I'm very happy about it. However, the X does still "flop" over when transitioning direction.
I would give the EE Bar a 9 out of 10 overall. Easy install, fair price, and nearly complete kit (ENDLINKS!!!) with immediate results with increased safety and handling without sacrificing comfort.
First impressions of the Energy Suspension front end sway bar bushing kit was "that's it?" Yep, only new sway bar bushings and end links (with new bushings). At less than $40 for the kit, it was worth a try.
The install was very easy, a 1 out of 10 for difficulty (maybe a 2 if your bolts are rusted). I did it in my garage in the dark by myself. It took less than 30 minutes.
No instructions are included, but it's pretty self explanatory. First, I loosened the 2 bushing mounts, and removed one (but leave the other attached). I lubed up the new bushing and slipped it over the cleaned bar. I carefully reattached the original bracket, but didn't tighten. Repeat for the other bushing.
HINT: Keep an eye on the bushing and the bushing mount when tightening. The bushing is a snug fit in the mount.
After tightening down the sway bar bushing mounts, remove the end links. Do both at the same time. They are long bolts with a ny-lock nut on the bottom. Pull the ends of the sway bar down to help slip the end links out.
The Energy Suspension end links looked impressive with their gold-color, but I couldn’t imagine them being much better than the stock ones. In they went with no problems.
Initially the result was hardly noticeable. Driving around town the handling didn’t seem to change. However, once at highway speeds, the X didn’t “flop†into the turns. I could dart around changing directions in a controlled manner with predictable results. YEA!!!
I would give the Energy Suspension front sway bar bushing kit a 10 out of 10!!! A great price, easily installed (even without instructions), and good results improving safety and predictability without sacrificing comfort.
Between the EE rear bar, and the Energy Suspension bushings, I’m very happy with the way it handles. A recent trip up to Tahoe (hwy 50) was very satisfying as I took turns faster than ever. Driving the X over 80 mph is now confident and secure.
P.S. I do plan on installing Bilstein shocks in the near future, as well as playing with the bump-stop height for some further suspension tuning.
-Brad
-Brad
