Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Elite Explorer 911!
Notices
Elite Explorer 911! 911! is for situations where your truck is currently out of commission and the owner is in a crisis situation. Members will try to answer your questions asap, no time frame is guaranteed. Only Elite Explorers can post new threads in this forum
93 XLT 4x4 wont engage
Reply
Thread Tools
Old 12-14-2004, 01:23 AM   #1
93XLTrusty
Boone, NC
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Unhappy 93 XLT 4x4 wont engage
Ok so there is a snow storm outside and i was driving to a friend's place and decided to play in a parking lot on the way. When i tried to engage the 4x4 it wont work. I have a 93 XLT with push button transfer case and automatic locking hubs. I Just used the 4x4 successfully a few days ago, so I cant figure out why it wont engage now. I let my car warm up for about 5-10 mins before i drove it. I tried engaging 4x4 in every gear and still nothing. When I push the 4x4 button, i noticed my instrument panel lighting dims slightly for a scond, and the volt meter dips. I really need 4x4 to get around in this weather so HEEEELP PLEASE!!!
93XLTrusty is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-14-2004, 01:44 AM   #2
jimbo74
Elite Ranger
Nor*Cal
jimbo74's Avatar
98 XLT Supercab 4x2
Vehicle Specs
Quoted: 0 Post(s)
sounds liek a possible frozen transfercase shift motor
__________________
My Truck
jimbo74 is offline   Reply With Quote
Old 12-14-2004, 02:18 AM   #3
93XLTrusty
Boone, NC
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
So, is there a cheap fix for a frozen tranfer case motor? I read on another thread in here someone said you can get a friend to tap the motor with a hammer while you try to engage the transfer case. Does this work and where on the truck is this motor?
Old 12-14-2004, 03:05 AM   #4
Brain
Golden, CO
'92 4X EB and '91 4X XLT
Vehicle Specs
Quoted: 0 Post(s)
Underneath behind the transmission is the transfer case. The shift motor is on the back of the transfer case.
Brain is offline   Reply With Quote
Old 12-14-2004, 06:56 AM   #5
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Welcome to the site.
Shift motor problems are common on 1st Gen (91-94) Explorers... Tapping on the shift motor may help nudge it to work. The operative work is tap not beat to death... There are many threads on this topic so searching this board witll land many hits. Check out the shift motor link in my sig line to get you started. IMO the problem is partly design related and partly due to intermitant use. Lack of use tends to slowly freeze the motor into position until it draws too many amps and is shut down by the 4x4 controller in the trunk area. Once you get it working don't be stingy wtih 4x4 and engage it a few times a month to keep it in good working order.
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 12-14-2004, 11:07 AM   #6
TheGreatOne
Staten Island NY
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
My explorer is having the same problem...push the buttons, but the orange lights do not come on.
Does anyone have a picture or service manual illustration of what the shift motor looks like?? Before I go bashing things with a hammer I want to make sure it's the right part!
Also, I checked out the other thread linked in this one, about the shift computer....where exactly is it located?? In the back behind the removable panel? Where the jack and tire iron are, and the washer fluid reservoir?? Does it have 3 seperate harness connections (2 plug type and one hardwired)? Could it be easily mistaken for a factory amp and accidentally removed? :-) And if so where can I get another one?
TheGreatOne is offline   Reply With Quote
Old 12-14-2004, 11:23 AM   #7
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Yes... You've chucked your 4x4 controller... Time to visist a boneyard for one.
__________________
Old 12-14-2004, 09:11 PM   #8
93XLTrusty
Boone, NC
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
^^There is a sound amp back there but you have to remove the whole side panel in the trunk to get to it. If i remember correctly its mounted on the pillar. About the 4x4. I slithered under my truck today and tapped the shift motor with a hammer. When i pushed the 4x4 button the lights lit up as they should, but when i tested my traction on a patch of ice, I found that my front wheels arent getting any power. What could this problem be? I called a local 4x4 shop and they said they would jack it up and take a look no charge tomorrow morning. But if there is something i can do myself i would much rather. Thanks for all the help guys...
Old 12-15-2004, 06:48 AM   #9
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
The 4x4 controller is the box to the right of the washer fluid reservoir in the first pic. The stock amp is located on the right side of the vehicle as seen in the 2nd picture.
Right side - Stock amp location
__________________
Old 12-16-2004, 11:53 AM   #10
93XLTrusty
Boone, NC
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Update! I took my truck to a local 4x4 shop and had a guy take a look. He crawled underneath and had me engage 4x4 and rool forward and back. He said that my auto locking hubs were engaging and disengaging as they are supposed to. He said my front drive shaft is not turning via the transfer case. He recommended i take it to a Ford dealership and have them look at the solenoid. Any thoughts or comments are welcome here. Could the problem be the 4x4 computer in the back or is it definately in the transfer case?
Old 12-16-2004, 03:00 PM   #11
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
The above is not 100% clear. You wrote the hubs locked and unlocked correctly, but the T-case didn't turn the front drive shaft. This doesn't make sense (unless you mech manually rotated the shaft as in the testing procedure below). Your autohubs will only lock if the axle shaft is being powered. This would mean the front drive shaft is also turning, which means the T-Case must be correctly sending power to the front shaft.
Any easy test to Verify your HUBs work correctly:
Crawl under your Explorer with the wheels on the ground and engine off. Rotate the front driveshaft in one direction. This will rotate the left and right axles which (after several rotations) will lock the hubs. When the hubs lock you will hear and feel a slight click. If the HUBS are working correctly you will NOT be able to rotate the front shaft anymore. If you can continually rotate the front driveshaft then the axle shaft the moves is the one with the broken HUB.
__________________
Old 12-16-2004, 03:02 PM   #12
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
Can I assume that this means you have replaced the 4WD computer? If you have a good computer in there and the t-case still won't shift, it's likely the shift motor.
One comment on taking it to Ford (or most shops for this). If they determine the fault is the shift motor, they are going to sell you a new motor. "By the book" there's no such thing as cleaning/rebuilding the shift motor.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 12-16-2004, 03:52 PM   #13
93XLTrusty
Boone, NC
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
^^ I just performed the test on my hubs. With my engine off and the explorer in park, I crawled underneath and rotated the front driveshaft. It turned a few times then i heard some clicks and it wouldn't turn that direction anymore. I could rotate it the opposite direction a few times then it would stop. I assume this means my hubs are working properly. Are there anymore tests I can perform myself to determine what the problem is? If I was to locate my 4x4 computer what would I look for when i found it? IS there a fuse on it?
Old 12-16-2004, 03:59 PM   #14
TSTONE
Giddy up!
Oakland County, MI
TSTONE's Avatar
97 Mountaineer
Vehicle Specs
Quoted: 1 Post(s)
Are you getting any noise from the transfer case when hitting the 4wd button?
Did you ever search the threads concerning removal and cleaning of the tranfer case motor? That is the most common cause of 4x4 not engaging.
__________________
“Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, pork rhines in one hand, bottle of jack in the other, body thoroughly used up, totally worn out and screaming “WOO HOO what a ride!”
TSTONE is offline   Reply With Quote
Old 12-16-2004, 04:22 PM   #15
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 3 Post(s)
Ok it appears your hubs are working.. When you press the 4x4 button what happens and what do you hear? Does the light next to the 4x4 dash button and 4x4 panel indicator light come on? Do you hear/feel the T-Case shift into 4x4?
__________________
Old 12-16-2004, 04:37 PM   #16
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
Its the shift motor, take it off, rebuild it according to the instruction on this and other sites and save yourself some cashola. Ford will sell you one for about $300, I have rebuilt 9 of them to date, all 9 still work perfectly as far as I know.
Also once you have the shift motor off you can shift the transfer case by hand with pliers, just remember you must be in N to put it in low range.
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 12-16-2004, 06:24 PM   #17
93XLTrusty
Boone, NC
'93 XLT
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
(i accidentally posted this in the wrong topic the first time)
Well I dont know what I did, but the transfer case is working now!!! I have shifted in and out of 4x4 twice with no problem! I tested it out on some dirt, just to make sure it was working......
Thanks for all the help guys. I am definately going to take your advice and use the 4x4 at least once a month. I know the manual says not to use 4x4 on pavement, but is a few miles ok?
Again, thanks!
Old 12-17-2004, 09:25 AM   #18
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
a few miles in high range wont kill it, just dont turn sharp.
Dont be surprised if it quits working again soon, this is another sign that its the shift motor
__________________
Old 12-28-2004, 10:17 PM   #19
freedo
rosemount, MN
'94 xlt
Vehicle Specs
Quoted: 0 Post(s)
the same thing happened on my '94 xlt, the problem was that the selenoid went bad and that is a simple fix, you could have simply gone to your local junk yard or used parts store and probably found the selenoid for about $45-$60. That's all i did and it works fine.
freedo is offline   Reply With Quote
Old 12-28-2004, 11:36 PM   #20
Glacier991
EF Tranny Guru
Sacramento, CA 95827
1992 XLT
Vehicle Specs
Quoted: 5 Post(s)
Check out the "Rebuilding the 4WD Shift Motor," by Brain.. it is in the Useful Threads forum.
Glacier991 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
