#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
How to: Rebuild 4X4 Shift Motor
Reply
Thread Tools
Old 02-03-2007, 11:38 AM   #161
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Have you tried driving it anywhere? I'm thinking the T-case is cold causing the shift motor to be unable to move it... Once it warms up it will definitely have an easier time shifting. I assume you hear the relays clicking in the back correct?
__________________
John D-"Search first, Ask questions later" & "You can have my Explorer when you pry the keys from my cold dead hands." <<<Forum Rules >>>*My Truck*
4x4 Trouble Shooting Guide
See how cars work Axle and tire calculators U-joint replacement info/pics
Repair info NEX-New England Explorers NEX: Club Events
DeRocha is offline   Reply With Quote
Old 02-03-2007, 11:53 AM   #162
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
dont hear any thing yes i have been driving it 30 to 40 miles at a time and trying to get it to do any thing while im driving i push the button while im driving while im at a stop sign at 40 miles a hours and 10 miles a hour also tried it with the power on but the engion off clutch pressed and not pressed
a711112a is offline   Reply With Quote
Old 02-03-2007, 11:57 AM   #163
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
luckley i have manual hubs so i can un lock them
Old 02-03-2007, 01:26 PM   #164
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Well if you don't hear anything the 4x4 computer isn't doing anything... Usually when you have a problem you'll hear the relays clicking and then nothing (shift motor does zip).. Did you hear the relays before and is the fuse ok?
__________________
Old 02-03-2007, 01:55 PM   #165
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
wher do i find the fuze
the light lits up saying it is in 4/4
Old 02-03-2007, 01:58 PM   #166
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
the relays were never very loud
Old 02-05-2007, 10:26 PM   #167
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
pulled it this afternoon lit it hang and pushed the button it went back cycled it a couple times re instaled it afraid to push it again
i think i have a weak motor how do you fix that ?
rocha thanks for your help
Old 02-05-2007, 11:13 PM   #168
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
i pushed the test button on the computer and a red light came on and stayed on for almost a minuit what does that meen ?
Old 02-06-2007, 07:49 AM   #169
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
Cleaning it is the only way.. that and making sure the T-Case selector shaft moves freely.. If you seldom use 4x4 the shaft can gradually get harder and harder to move... Sort of like never using the E-brake and then one day using it and it stays on and won't release... I would get some nice pliers and rotate the T-case selector shaft through all its positions a bunch of times. While doing this you can feel how hard it is to move the shaft and if it loosens up some..
Pushing the button without removing the wire harness connector on the right side means nothing..
__________________
Old 02-07-2007, 10:35 PM   #170
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Could a moderator remove this last post with spam?
BrooklynBay is offline   Reply With Quote
Old 02-07-2007, 10:40 PM   #171
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
de rocha tell me more aboutis removing the wire harness connector on the right side it the one that hanges to the tab on the top with 6 wires going to the black box on the right side
Old 02-07-2007, 10:41 PM   #172
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
i meen 7 wires
Old 02-07-2007, 10:46 PM   #173
a711112a
GALENA MO
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
i also did a a4ld to m5od swap. swaped out the wire harness and did not cut any wires. now that it is done i cant get it to go into 4 low. when it was in the m50d doner truck it worked well.
Old 02-11-2007, 01:20 PM   #174
BluOvalMan
Charlestown, WV
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
Would anyone have a FORD Part No# for the bushing (cushion) on the back of the large gear? Part No# or something I can use in its place. Rebuilding motor and the bushing is broke into a dozen pieces.
Was thinking maybe some vacuum line or something. Any ideas would be great.
BluOvalMan is offline   Reply With Quote
Old 02-11-2007, 03:06 PM   #175
shamal
Victoria, BC
shamal's Avatar
1993 4x4 Explorer Stock
Vehicle Specs
Quoted: 3 Post(s)
Bluoval: We use rubber gas line, it works great !
__________________
Shamal
Victoria, BC
'93 Expl 4x4 4.0
shamal is offline   Reply With Quote
Old 02-11-2007, 04:31 PM   #176
BluOvalMan
Charlestown, WV
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
What size fuel line? I would guess the wall thickness would make a difference.
If fuel line works, that would be awrsome, I may get this done before dinner..
Old 02-11-2007, 05:03 PM   #177
DeRocha
NEX Vice President
Brockton, MA
DeRocha's Avatar
'93 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
5/16"
__________________
Old 03-01-2007, 06:44 PM   #178
Bwana Bob
Morris Plains, NJ
92 XLT
Vehicle Specs
Quoted: 4 Post(s)
She's fixed! Share my joy!
I want to thank Brain and all the other posters. The shift motor overhaul information here (and in the Singleton thread) is excellent, better than any shop manual.
I fixed mine this past Sunday. It was the classic problem: The plastic bushing was shattered into lots of tiny pieces, some of which got ground up in the gears. I replaced it with the suggested piece of fuel line and cleaned the motor commutator and the position sensor contacts.
I got it all back together and tested, just as the first few snowflakes appeared. As it turned out, I didn't need 4WD, but when I got to work on Monday, I did a few victory laps in the unplowed part of the parking lot. I made some nice alien 4-wheeler crop circles
It even seems to shift into 4WD faster, with less delay.
Cost of hardened T-20 security Torx bit (my cheap one twisted) $5.00
Cost of fuel line: $0.00
Sound of 4WD engaging (click, click, clunk) and sight of "4X4" lamps: Pricless!
Brain, et al, I salute you
Bob
__________________
1992 XLT semi-retired: Manual trans, Manual hubs, brush guard, Hella fog lamps, K&N air filter, Michelin LTX/MS, 241,000+ miles. Daily driver: 2010 Focus SES. Amateur Radio WB2VUF
Bwana Bob is offline   Reply With Quote
Old 03-10-2007, 03:42 PM   #179
djbiker27
Torrance, CA
1999 4x4 Ranger P.O.S.
Vehicle Specs
Quoted: 0 Post(s)
so i took apart my t-case motor this morning while most of my friends are taking the SATs haha and wouldn't you know it a broken bushing!!!! haha. i'm waiting for my friend to give me a ride to like pepboys or home depot or something to find a replacement. hopefully it will work now. and since i'm 16 and don't have a job and only like $6 it's good that i'm learning how to fix my explorer instead of paying someone like $500 haha.
thanks for the help and i'll let you guys know if it works or not!
djbiker27 is offline   Reply With Quote
Old 03-10-2007, 05:07 PM   #180
ellis11
oxford, MI
97 sport
Vehicle Specs
Quoted: 0 Post(s)
This has been a very usefull and interesting thread. I've had my 97 Explorer Sport for about 2 1/2 years but rarely drove it except to pull my boat since it is my wifes car. I never knew for sure if it ran in 4WD since I'd never experienced it before and didn't notice any difference. After reading this thread I checked Autozone for the price of a new transfer case motor and purchased it for $109.00 and waited for the weather to warm up a bit. Well it warmed up enough today so I climbed under the car and installed it and discovered that this car has never been in 4WD since I owned it even though the 4WD lights lit up, Until Today. Now I know what 4WD is.
Next project is to replace a door handle and then do a transmission valve body rebuild with a Transgo shift kit.
Thanks to all!
ellis11 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Shift motor replacement - Removing/Replacing the Brown Wire hamptonhills Explorer & Ranger Transmissions, Transfer Cases, & Differentials 3 10-18-2014 10:07 PM
4x4 problems after repalcing shift motor - FIXED agobbie Stock 1991 - 1994 Explorers 17 12-16-2013 08:56 AM
shift motor rebuild problems??????? ranger-93 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 0 10-11-2009 11:37 PM
rebuilt '91 4x4 shift motor install - adjust? mpierich Under the Hood 5 01-09-2005 03:29 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
