Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Body Work & Detailing
Notices
Body Work & Detailing Waxing washing, wheel cleaning and body work. This is the place to discuss those topics.
Quick repair of locked rear door assembly
Reply
Thread Tools
Old 12-30-2004, 10:51 AM   #1
Baileybc
Bend Oregon
'97 XLT
Vehicle Specs
(Original Poster)
After reading this forum, I got the nerve to attempt a removal of the left rear door panel on my 97 XLT to access the lock mechanism. The door could not be opened from inside or outside without removal of the panel. The culprit was a broken spring, interior to the handle return mechanism. If the spring breaks, the latch activator rod (threaded and with a plastic part on its end) will be stuck in the full down position. As such, the latch will not be engaged unless the rod is pushed upwards, towards the broken spring.
The fix is simple. I went to Home Depot and bought a Handyman Spring, SP-9602 (Prime-Line Slide-Co), $1.95 for two springs. I hung the Handyman spring onto the broken Ford spring, which had slipped down over the latch handle interior mechanism, making a good anchor position. Next, I took a 6 inch section of metal coat hanger and put a a loop the end using a standard shop screwdriver as a template for the hole diameter. Now I bent a right angle into the loop end so the part then resembled an "L". Put a loop in the other end of the hanger to attach to the Handyman spring, after fiddled a bit with the correct length to just get a slight positive load on the spring and the job was done. Since the springs come in sets of two, I made a precautionary repair of the still-functioning right rear door.
The driver side door had a broken handle-return-spring as well (where is Ford purchasing these sub-standard spring??!), so back to HD for another set. This broken spring issue can render the rear seats unsafe in a crash, since the doors cannot be opened for an egress.
Each door can be repaired in about 20 minutes using this method, and functionally, the new spring does the job required. Write to me if you want some detailed pictures.
Baileybc is offline   Reply With Quote
Old 10-27-2007, 03:59 PM   #2
savage243shooter
Humble, TX
1997 XLT 4wd
Vehicle Specs
rear door
Please send some photo's if still posible. Thanks in advance. AK
savage243shooter is offline   Reply With Quote
Old 05-02-2010, 05:38 PM   #3
Hunny
Cleveland
99 XLT
Vehicle Specs
XLT Rear door latch
Great info, I was able to remove the panel but how did you get the latch to release so you could open the door and unscrew the latch?
Hunny is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
